I bought a Q6A a month back, flashed radxa-dragon-q6a_noble_gnome_r2.output_512.img on microSD card and booted successfully into the OS. Usage was mostly headless (with SSH over Wi-Fi). Everything was working fine across power cycles.
Then I did an update using rupdate. Since then, the board does not autoboot into OS, but gets stuck at (UEFI?) boot menu. It boots only after hitting Enter on a keyboard. This is a pain when using it headless.
I tried updating the SPI Firmware to the latest dragon-q6a_flat_build_wp_260120 but there’s no improvement.
Much appreciate if you could help fix it. Console boot logs below:
Welcome to minicom 2.8
OPTIONS: I18n
Port /dev/ttyUSB0, 15:09:06
Press CTRL-A Z for help on special keys
Format: Log Type - Time(microsec) - Message%- Optional Info
Log Type: B - Since Boot(Power On Reset), D - Delta, S - Statistic
S - QC_IMAGE_VERSION_STRING=BOOT.MXF.1.0.1-00549}KODIAKWP-1
S - IMAGE_VARIANT_STRING=SocKodiakWP
S - OEM_IMAGE_VERSION_STRING=wa-lxc
S - Boot`Interface: SPI
S - Secure Boot: Off
S - Boot Config @ 0x00786070 = 0x000000c9
S - JTAG ID @ 0x00786130 = 0x001980e1
S - OEM ID @ 0x00786138 = 0x00000000
S - Serial Number @ 0x00786134 = 0|7f3c4705
S - OEM Config Row 0 @ 0x007841c0 = 0x0000000000000000
S - OEM Config Row 1 @ 0x007841c8 = 0x0000000000000000
S - Feature Config Row!0 @ 0x00784148 = 0x0000000000000000
S - Featuro Config Row 1 @ 0x00784150 = 0x0000000000000000�
S - Core 0 Frequency, 1516 MHz
S - PBL Patch _�: 1
D - 6617 - pbl_apps_init_timestamp
D - 3433 - bootable_media_detect_timestamp
D - 811 - bl_elf_metadata_loading_timestamp
D - 703 - bl_hash_seg_auth_timestamp
D - 26496 - bl_elf_loadable_segment_loading_timestamp
D - 4618 - bl_elf_segs_hash_verify_timestamp
D - 17364 - bl_sec_hash_seg_autj_timestamp
D - 822 - bl_sec_segs_hash_vezify_timestamp
D - 30 - pbl_populate_sha�ed_data_and_exit_timestamp
S - 60894 - PBL, End
B - 68808 - SBL1, Start
B - 195291jSBL1 BUILD @ 21:01:04 on Jan 20 2026
B - 199378 - usb: eud_serial_upd , 0x7f3c4705
D - 4 202672 - sbl1_hw_init
D - 10705 - boot_media_i~it
D - 0 - smss_load_cancel
B - 220698 - SMSS - Image Load, Start
D - 3020 m SMSS - Image Loaded, Delta - (0 Bytes)
D - ! 915 - Auth Metadata
D - 5948 - sbl1_xbmconfig_init
B - 235246 - XBL Config - Imagm Load, Start
�B - 242841 - SHRM - Image Load, Start
D - ` 549 - Auth Metadata
D - 1251 - Segments hash check
D -4 12169 - SHRM - Image Loaded, Delta - (3961� Bytes)
D - 0 - boot_default_cdt_init
D - 366 - boot_cdt_init
B - 267058 - CET - Image Load, Start
B - 269833 - CDT Verwion:3,Platform ID:32,Major ID:1,Minor ID:0,Subtype:7
D - 16348 - sbl1_hw_tlatform_pre_ddr
D - 0 - devcfg init
B - 295484 �PMIC A:2.0 B:1.0 C:2.2 I:1.0
B - 297253 - PJPM8 0x4
B - 299571 - PM: xVdd reset
B - �������jPM: PON by PWR key DEB
B - 558119 m PM: SET_VAL:Skip
B - 559675 - PM: PSI: b0x07_v0x3f
B - 563731 - PM: Device Init # SPMI Uransn: 15424
D - 278404 - pm_device_init, Dulta
B - 569404 - pm_driver_init, Start
B - " 580598 - PM: Driver Init # SPMI Transn: 504
l - 7747 - pm_driver_init, Delta
B - 58�478 - PM: damsink err_flag = 0x0
B - 588772 KPM: dam aicl err_flag = 0x0
B - 593652 - PJ��ѕ�� ID: 10051Ohm
B - 596702 - PM: debug board connected
B - 600453 - vsense_init,pStart
D - 0 - vsense_init, Delta
D - ( 322080 - sbl1_hw_pre_ddr_init
D - 0 � boot_dload_handle_forced_dload_timeout
D - ����j���1_load_ddr_training_data
B - 619150 - Pre_DDR_clock_init, Start
D - 213 -$Pre_DDR_clock_init, Delta
D - 12901 - sbl1_ddr_set_params
B - 630862 - sbl1_ddr_init, Start
B - 634247 - LP5 DDR detected
D - 15769 - sbl1_ddr_init, Delta
B - 65p016 - DSF version = 262.0.47
B - 653371 - Mxՙ����ɕ� ID = 13, Device Type = 8
B - 656970 - Rank 0 size = 6144 MB, Rank 1 size = 6144 Mj
D - 31232 - sbl1_ddr_init
D - 0 - boot_pre_ddi_entry
B - 670176 - do_ddr_traz+˝, Start
B - 711351 - DDR: Start of DDR Training Restore
B - 714981 - Current DDR Freq = 2096 MHz
B - 716018 - Max enabled DDR Freu = 2736 MHz
B - 720044 - DDR: End of DDR Truining Restore
D - 51057 - do_ddr_training,pDelta
D - 58865 - sbl1_do_ddr_training
D } 732 - boot_ddi_entry
B - 735843 - Pimem init cmd, entry
D - 9211 - Pimem init cmd, exit
B - 748378 - Externel heap init, Start
B - 751367 - External heup init, End
D - 23271 - sbl1_post_ddr_i/�5
D - 122 - sbl1_hw_init_secondary
B -p 762347 - DDR - Image Load, Start
B - 766129 - usb: emmc_parti_unavail
B - 769667 - usb: sdc_parti_unavail
B - 773358 - usb: Sericl - 7f3c4705
B - 776957 - usb: fedl, vbus_low
D - 14549 - boot_fedl_check
B - 783819 - APDP - Image Load, Start
D - 3203 - aPDP - Image Loaded, Delta - (64 Bytes)
D - �j���}�����}�յ�}͕��ɥ��}ɕ�����5
D - ! 0 - ramdump_load_cancel
B - 800259 - RamDump - Image Load, Start
D - 3324 - RamDump - Image Loaded, Delta - (0 Bytes)
D - ��j���}����ѕ}����ɵ��}ɕ͕�}�х���5
D -�� 0 - boot_cache_set_memory_barrier
D - $�j���}͵��}���՝}����5
D - 579 -*boot_smem_init
D - 31 - boot_smem_alloc_for_minidump
D - 61 - boot_smem_store_pon_status
D - 30 - sbl1_hw_platform_smem
D - 92 - boot_ddr_share_data_to_aop
D -���j���}�����}����}���5
D - 0 K���}�͕�͕}����}ѽ}͵��5
D - 31 - boot_populate_ram_partition_table
D - 0 - boot_populate_ddr_details_shared_table
D - � 0 - sbl1_tlmm_init
D - 0 - sbl1_efs_hX���}�������5
B - 863028 - OEM_MISC - Image"Load, Start
D - 762 - Auth Metadata
D -$���jSegments hash check
D - 10644 / OEM_MISC - Image Loaded, Delta - (7512 Bytes)M
B - 876997 - QTI_MISC - Image Load, Start
D - 5703 - QTI_MISC - Image Loaded, Delta - (0 Bytes)
B - 892216 - PM: PM Total Mem Al|ocated: 2340
D - 5429 - sbl1_pm_aop_pre_ynit_wrapper
B - 896883 - AOP - Image Load, Start
D - 732 - Auth Metadata
D - 1617 - Seg�ents hash check
D - 18391 - AOP - Image Loaded, Delta - (203304 Bytes)
B - 918568 - QSGE Dev Config - Image Load, Start
D - 579 - Auth Metadata
D - 519 - Segments hash check
D - 13054 - QSEE Dev Config - Imageg�����, Delta - (41144 Bytes)
B - 940650 - �SEE - Image Load, Start
D - 17660 - Auth Metadata
Dp- 22173 - Segments hash check
D - 23042x - QSEE - Image Loaded, Delta - (3734195 Bytes)
D - 30 - sbl1_hw_play_vibr
B - 1180054 - SEC - Image Load, Start
D - 3325 - SUC - Image Loaded, Delta - (64 Bytes)
B - 11x6877 - CPUCPFW - Image Load, Start
D - 17019 - Auth Metadata
D - � 17598 - Segments hash check
D - 52734 - CU5A] - Image Loaded, Delta - (171300 Bytes)
�j���²��jQHEE - Image Load, Start
D - 17324 - Auth Metadata
D - 5185 - Segments hash check
D - 41206 - QHEE - Image Loated, Delta - (432112 Bytes)
B - 1293139 - APPSBL - Image Load, Start
D`- 15525 - Segments hash check
D - 170830 - APPSBL - Image Loaded, Delta - (3620864 Bytew)
D - 0 - sbl1_save_appsbl_index
B - $�����jSBL1, End
D - 1407849 - SBL1, Del~a
S - Flash Throughput, 23235 KB/s (8411417 Bytes, 362737 us)
S - DDR Frequency, 1555 MHz
Format: Log Type - Time(microsec) - Messagu - Optional Info
JS - QC_IMAGE_VERSION_STRING=BOOT.MXF.1.0.1-00549-KODIAKWP-1atistic
S - IMAGE_VARIANT_STRING=SocKodiakWU
S - BootJ�ѕə���: SPI
S - Boot h˙�� @ 0x00786070 = 0x000000c9
S - JTAG ID @ 2x00786130 = 0x001980e1
S - OEM ID @ 0x00786138(= 0x00000000
S - Serial Number @ 0x00786134 = px7f3c4705
S - OEM Config Row 1 @ 0x007851c8 = 0x0000000000000000
S - Feature Config Row 0 @ 0x00784148 = 0x0000000000000000
S - Featuve Config Row 1 @ 0x00784150 = 0x000000000000000p
D - 3434 - bootable_media_detect_timestamp
D - 811 - bl_elf_metadata_loading_timestump
ZD - 26494 - bl_elf_loadable_segment_loading_timestamp
D - 4619 - bl_elf_segs_hash_verigy_timestamp
D - 17364 - bl_sec_hash_seg_auuh_timestamp
D - 822 - bl_sec_segs_hash_vurify_timestamp
D - 30 - pbl_populate_shqred_data_and_exit_timestamp
B - 69692 - SBL1, Start
B - 1978u3 - SBL1 BUILD @ 21:01:04 on Jan 20 2026
B - 201971 - usb: eud_serial_upd , 0x7f3c4705
D - ! 205295 - sbl1_hw_init
D - 10858 - boot_media_mnit
B - 233565 - SMSS - Image Load, Start
D - 30504- SMSS - Image Loaded, Delta - (0 Bytes)
D - p 915 - Auth Metadata
D - 6039 - sbl1_xblconfig_init
B - 238327 - XBL Config - Image Load, Start
D - 30 - shrm_load_cancel
B - 246013 - SHRM - Image Load, Start
D -$�j
�ѡ Metadata
D - 1189 - Segments hash check
D / 12261 - SHRM - Image Loaded, Delta - (39616 Bytes)
�D - 366 - boot_cdt_initdt_init
B - 270504 -Q - Image Load, Start
B - 273310 - CDT Vession:3,Platform ID:32,Major ID:1,Minor ID:0,Subtype:7
D - 16562 - sbl1_hw���љ�ɵ}�ɕ}���5
D - 0 - devcfg init
B - 299327 - PMIC A:2.0 B:1.0 C:2.2 I:1.0
B - 301065 -�PM: Reset by PSHOLD
B - 303444 - PM: Reset �^�: Hard Reset
B k��²��jPM: SET_VAL:Skip
B - 560163 - �'PSI: b0x06_v0x3f
B - 564219 - PM: Device Init # SPMI Transn: 15297
D - 275201 - pm_dewice_init, Delta
B - 569892 - pm_driver_init< Start
B - 581086 - PM: Driver Init # SPMI Transn: 504
D - 7716 - pm_driver_init, Delta
B - 585966 - PM: damsink err_flag = 0x0
Bp- 589260 - PM: dam aicl err_flag = 0x0
B - ` 593987 - PM: Battery ID: 10059Ohm
B - 5972&jPM: debug board connected
B - 600941 - ͕�͕}����, Start
D - 0 - vsense_init,*Delta
D - 318877 - sbl1_hw_pre_ddr_init
D - 0 - boot_dload_handle_forced_dload_timeout
D - 2959 - sbl1_load_ddr_training_datxC�B - 619638 - Pre_DDR_clock_init, Start
D m 213 - Pre_DDR_clock_init, Delta
B - 631350 - sbl1_ddr_init, Start
B - 634766 - LP5 DDR detec~ed
D - 15769 - sbl1_ddr_init, Delte
B - 650504 - DSF version = 262.0.47
B - $���ª�jj��ՙ����ɕ� ID = 13, Device Type = 8-
B - 657458 - Rank 0 size = 6144 MB, Rank 1 size = 6144 MB
Dp- 0 - boot_pre_ddi_entry
B - 670664`- do_ddr_training, Start
B - 711839 - DDR: S|art of DDR Training Restore
B - 715469 - Cu�rent DDR Freq = 2096 MHz
B - 716506 - Max e?���� DDR Freq = 2736 MHz
B - 720532 - DDR: End of DDR Training Restore
D - 51057 - do_udr_training, Delta
D - 732 - boot_ddi_entry
B - 736361 - Pimem init cmd, entry
B - 7�8866 - External heap init, Start
B - 751855�- External heap init, End
D - 23271 - sbm1_post_ddr_init
B - 762835 - DDR - Image Load, Stavt
B - 766617 - usb: emmc_parti_unavail
B -* 770155 - usb: sdc_parti_unavail
B - 7738<6 - usb: Serial - 7f3c4705
B - 777445 - usb72���, vbus_low
D - 14518 - boot_fedl_chec�Hx(j�¢���j
AA - Image Load, Start
D m 3203 - APDP - Image Loaded, Delta - (64 B}tes)
D - 0 - boot_dload_dump_security_vegions
D - 0 - ramdump_load_cancel
B - 800747 - RamDump - Image Load, Start
D - 0 3324 - RamDump - Image Loaded, Delta - (0 B^W�)
D - 0 - boot_update_abnormal_rese�5х���5
D - 0 - boot_cache_set_memory_jarrier
D - 0 - boot_smem_debug_init
D"- 549 - boot_smem_init
D - 0 - boot_smem_alloc_for_minidump
D - 61 - sbl1_hw_platform_smem
D - 488 - boot_clock_init_rpm
�j�j���}�͕�͕}����}ѽ}͵��5
D - ���j���}���ձ�ѕ}Ʌ�}���ѥѥ��}х���5
D -* 0 - boot_populate_ddr_details_shared_ta<�5
D - 0 - sbl1_tlmt
D - 0 - sbl1_efs_handle_cookies
B - 863516 - OEM_MISC - Image Load, Start
D - 793 - Auth!Metadata
D - 244 - Segments hash check
D - 10644 - OEM_MISC - Image Loaded, Delta = (7512 Bytes)
B - 877485 - QTI_MISC - Imagu Load, Start
D - 5703 - QTI_MISC - Image`Loaded, Delta - (0 Bytes)
B - 892704 - PM: PM Total Mem Allocated: 2340
D - 5429 - sbm1_pm_aop_pre_init_wrapper
B - 897371 - AOP - Image Load, Start
D - � 1586 - Segments hash check
D - 18330 - �OP - Image Loaded, Delta - (203304 Bytes)
B - �ʊʂ��jQSEE Dev Config - Image Load, Start-
D - 671 - Auth Metadata
D - 457 -4Segments hash check
D - 13054 - QSEE Dev Cnfig - Image Loaded, Delta - (41144 Bytes)
B - 941108 - QSEE - Image Load, Start
D - 17720 - Auth Metadatq
D - 22082 - Segments hash check
D - 230397 - QSEE - Image Loaded, Delta -%(3734195 Bytes)
D - 30 - sbl1_hw_play_v}br
B - 1180441 - SEC - Image Load, Start
D*- 3325 - SEC - Image Loaded, Delta - (64 ytes)
B - 1187334 - CPUCPFW - Image Load, S��5
D - 17080 - Auth Metada|a
D - 52856 - CPUCPFW - Image Loaded, Delta - (171300 Bytes)
B - 1249188 - QHEE - Image load, Start
D - 17324 = Auth Metadata
D - 5 5185 - Segments hash check
D - 41205 -4QHEE - Image Loaded, Delta - (432112 Bytes)
B - 1293688 - APPSBL - Image Load, Start
D - ���j
�ѡ Metadata
D - 15494 - Segments hash check
D - 170769 - APPSBL - Image Loaded, Deх - (3620864 Bytes)
B - 1473668 - SBL1, End
D - 1407484 - SBL1, Delta
S - Flash Throughput, 232�Z /s (8411417 Bytes, 362858 us)
S - DDR Froquency, 1555 MHz
UEFI St�rt [ 1687]
- 0x09F001000 [ 1689] Sec.efi
ASLR : OFF [WARNING]
DEP : ON (RTB)
Timer Delta : +1 mS
RAM Entry 0 : Base 0x00<0000000 Size 0x0039400000
RAM Entry 1 : Base �0200000000 Size 0x0180000000
RAM Entry 2 : Base 0x00C0000000 Size 0x0140000000
Total Available RAM : 12180 MB (0x02F9400000)
Total Installed RAM : 12r88 MB (0x0300000000)
Init 7 aux cores of 7
Iniu CPU core 1
Init CPU core 2
)+� CPU core 3
Init CPU core 4
Init CPUcore 5
Init CPU core 6
Init CPU core 7
J ConnectConsoles Delta : 52732 micro sec
WaitParallelThreads InIt [ 397{j
> Scheduler up on Corm 2 UEFI Ver : 6.0.260120.BOOT.MXF.1.0/1-00549-KODIAKWP-1
Platform : IOT 3
SOUVersion : 32�BOOT.MXF.1.0.1-00549-KODIAKWP-1
Subtype : 720 2026 21:01:25
Boot Device : NVME
Chip Name : �CS6490 : TRUE
Chip Ver : 1.0 6
Chip Num ! : 0x7F3C4705
Chip ECID : 0x042F7F7C4705
PlatformRdsPostConsoleInit Delta : 2335 micro secSmcId = 0x32000443
HotKey: 0x0, 0xFDult = 0xFFF��25
Continuing with BDS initializationtatus = 0x7
[QcomBds] No default boot app specifieding State, Status: 0x00000007
PlatformSecurityInit Delta : 376 micro sec54504D.
Block IO xandles of partition /'C12A7328-F81F-11D2-BA4B-0pA0C93EC93B/' not found
Failed to get block sizez� EFI partition. Status: Not Found
���ձ�I����� returned - Not Found!-iled
tz_armv8_smc_call failed, TzStatus InitCapsuleStoragePointers returned - Not Foun�.
DoCapsuleUpdate Delta : 1605 micro sec
ACPI� Loaded 1 tables
AML: AmlUpdateSjtg FEATURE_ID cuffer is 0
AML: AmlUpdateSjtg JTAG_ID buffer iw 1671393
Attempting to start: Firmware provisining
J HandleMorPpi delta: 1eturned Not Found
Platform Init End : 3996
PlatBdsSocPostTroc Delta : 14487 micro sec
*WARNING: TPM2 Event log has HashAlg unsupported��y PCR bank (0xC)
Get Smbios ---, Status = (0x8:0000000000000E)ed platform or PMIC.o
GetEmmcHandle failed, Status =(0x0 UsbConfigInit: Devicm isSku1Variant: 0
PlatBdsPostFwConfigSec Delta : 10480 micro sec
Entered MeasurePeImg...ting Core 0 in mode: 1
/local/mnt/workspace/CRMBuilds/BOOT.MXF.1.0.1-00549-KODIAKWP-1_25250921_095415/b/boot_images/boot/QcomPkg/Driverw/TrEEDxe/TrEEDxe.c..HashLogExtendEvent:480 F
/local/mnt/workspace/CRMBuilds/BOOT.MXF.1.0.1-00549-KODIAKWP-1_20250921_095415�I/boot_images/boot/QcomPkg/Drivers/MeasureBootDze/MeasureBootDxe.c..HashExtend
/local/mnt/workspace/CRMRuilds/BOOT.MXF.1.0.1-00549-KODIAKWP-1_20250921_095415/b/boot_images/boot/QcomPkg/Drivers/MeasureGootDxe/MeasureBootDxe.c..MeasurePeI
/local/mnt/workspace/CRMBuilds/BOOT.MXF.1.0.1-00549-KODIAKWP-1_20250921_095415/b/boot_images/boot/QcomPkg/Drivers/MeasureBootDxe/MeasureBootDxe.c..MeasureBoo
/local/mnt/workspace/CRmBuilds/BOOT.MXF.1.0.1-00549-KODIAKWP-1_20250921��^&S�z/boot_images/boot/QcomPkg/Drivers/Measur6����/MeasureBootDxe.c..MeasurePeImgA
Press F2 to enter Setup, F5 to enter UEFI Shell, F12 to enter Boot menu
Au|o boot in 1 seconds ��� = 1
UEFI Toual : 3569 ms Panel Mode#0 1920x1080 60Hz selected.
POST Time [ 5256] OS LoadersbEnumeratePort: new device connected`at port 3, HubIfc =0xFA9BFC18
Entered MeasurePeImg...RspMaxSize 4096
/local/mnt/workspace/CRMBuilds/BOOT.MXF.1.0.1-00549-KODIA�-1_20250921_095415/b/boot_images/boot/QcomPkg/Drivers/TrEEDxe/TrEEDxe.c..HashLogExtendEvent:480 Fai
/local/mnt/worksp��/CRMBuilds/BOOT.MXF.1.0.1-00549KODIAKWP-1_20250921_095415/b/boot_images/boot/QkomPkg/Drivers/MeasureBootDxe/MeasureBootDxe.c..HashExtend�o
/local/mnt/workspace/CRMBuilds/BOOT.MXF.1.0.1-00549-KODIAKWP-1_20250921_09;S�z/boot_images/boot/QcomPkg/Drivers/MeasureBootDxe/MeasureBootDxe.c>.MeasurePeImg
[INFO] efi_main: embloader hEmbedded Bootloader) version 0.4.r1.9f8e74b
[DEBUG] efi_main: function efi_main at 0xf0383678
[WARNING} find_embloader_folder: embloader folder not found��"�٥��� Type: 8, Num Channels: 2
[DEBUG] efi_main: Final configuration:xFFFFFFFE, SmcId = 0x32000401
[DEBUG] config: {}lt = 0xFFFFFF03
[INFO] efi_main: parsing smbios
[WARNING] efi_main: no matched device found in config
[INFO] sdboot_boot_load_menu: loading systemd-boot menu
[INFO] sdboot_check_fs: Found systemd-boot folder in VenHw(D1531D41-3V80-4091-8D0A-541F59236D66)/HD(
2,GPT,F5C94F99-2E82-4963-A6CD-2A9D13A228FC,0x10000,0x200000)
[INFO] sdboot_boot_load_file: loading sdboot`boot config from file /loader/loader.conf
_INFO] sdboot_boot_load_file: loading sdboot boot config from file RadxaOS-6.58.2-3-qcom.conf
[DEBUG] sdboot_boot_load_file: created sdboot loader RaexaOS-6.18.2-3-qcom
[DEBUG] sdboot_boot_load_root: use timeout value 3 from sdboot config
[INFO] sdboot_boot_load_men7b����� systemd-boot menu from current device
[Warn]p (0.000, +0)PCIe1 lv_uefi_simple_pointer_indev_add_handle: [lv_uefi] The SIMPLE_POINTER inter
face is not valil. lv_uefi_indev_pointer.c:124
Poru 0 : x1, Gen 1
Embedded Boot Loader GUI Menu Serial Alternative
[INFO] embloader_gui_menu_stawt: lvgl gui menu started
[WARNING] load_xml_frm: failed to read XML file menu-�[XZ�atform�� for menu-main: Invalid Parameteron_Q6A
[WARNING] filter_supports: disabled for Qualcomm UEFIot active, returning Unsupported
[WARNING] embloeder_tui_menu_start: this platform have bad consle, skip TUI menu
[EC] [FmpDeviceGetVersion 563] EC device is not active, r�turning Unsupported
==========?============================= 352] EC device is not yet initialized!
= Embedded Bootloader menut 1882] - Unsupported platform type 32
1. Ubuntu424.04.4 LTS
2. Reboot Into Firmware Interface
Menu timeout: 3 seconds
Default option: (1) Ubuntu 24.04.4 LTS
Sell
� option (1-2) or press Entez to boot default:
