Pure SD Boot, 3566
Having trouble booting linux from an SD card on a RK3566 Board
Here is my partition structure.
Part    Start LBA       End LBA         Name
        Attributes
        Type GUID
        Partition GUID
  1     0x00002000      0x00005fff      "uboot"
        attrs:  0x0000000000000000
        type:   0fc63daf-8483-4772-8e79-3d69d8477de4
        guid:   495cfe27-dcd2-42d0-b087-ce43753af54b
  2     0x00006000      0x00009fff      "misc"
        guid:   d49f7e11-67c2-41b9-95e3-c2f2aec54b60
  3     0x0000a000      0x00135fff      "boot"
        type:   ebd0a0a2-b9e5-4433-87c0-68b6b72699c7
        guid:   576e8ecc-f08e-44e1-af06-4a3844f487bf
  4     0x00136000      0x073ff7ff      "rootfs"
        guid:   7698d2db-1576-4c94-8e60-07c8bb2a5d78
Here is boot
=> ls mmc 1:3
      140   uEnv.txt
   112974   rk3566-rock-3a.dtb
  4613819   initrd.gz
 23861256   Image
     1474   boot.scr
Running the following
setenv bootcmd "load mmc 1:2 ${kernel_addr_r} Image; load mmc 1:2 ${fdt_addr_r} rk3566-rock-3a.dtb; booti ${kernel_addr_r} - ${fdt_addr_r}"
setenv bootargs 'console=ttyS0,115200 root=/dev/mmcblk1p3 rootwait init=/bin/sh debug'
Gets stuck at Waiting for root device /dev/mmcblk1p3.
MMC0 is the EMMC. i do not wish to boot from that, only SD card. If I set the same for mmcblk0p4 (emmc) it boots fine. So it looks like the SD is not mounting the correct partitions
Is there a change I need to make when compiling kernel (4.19) to allow mounting of the SD card partitions?
[    1.312995] mmcblk0: mmc0:0001 SLD64G 57.6 GiB
[    1.313811] mmcblk0boot0: mmc0:0001 SLD64G partition 1 4.00 MiB
[    1.314617] mmcblk0boot1: mmc0:0001 SLD64G partition 2 4.00 MiB
[    1.314894] mmcblk0rpmb: mmc0:0001 SLD64G partition 3 4.00 MiB, chardev (240:0)
[    1.332159] mpp_rkvenc fdf40000.rkvenc: probing start
[    1.332649] mpp_rkvenc fdf40000.rkvenc: Looking up venc-supply from device tree
[    1.332741] mpp_rkvenc fdf40000.rkvenc: Linked as a consumer to regulator.10
[    1.332763] mpp_rkvenc fdf40000.rkvenc: Failed to get leakage
[    1.332820] mpp_rkvenc fdf40000.rkvenc: pvtm = 85400, from nvmem
[    1.332839] mpp_rkvenc fdf40000.rkvenc: pvtm-volt-sel=1
[    1.333015] mpp_rkvenc fdf40000.rkvenc: avs=0
[    1.333333] mpp_rkvenc fdf40000.rkvenc: failed to find power_model node
[    1.333348] mpp_rkvenc fdf40000.rkvenc: failed to initialize power model
[    1.333360] mpp_rkvenc fdf40000.rkvenc: failed to get dynamic-coefficient
[    1.333740] mpp_rkvenc fdf40000.rkvenc: probing finish
[    1.334381] mali fde60000.gpu: Kernel DDK version g2p0-01eac0
[    1.334471] mali fde60000.gpu: Looking up mali-supply from device tree
[    1.334569] mali fde60000.gpu: Linked as a consumer to regulator.11
[    1.334584] mali fde60000.gpu: Looking up shadercores-supply from device tree
[    1.334601] mali fde60000.gpu: Looking up shadercores-supply property in node /gpu@fde60000 failed
[    1.334662] mali fde60000.gpu: Looking up mali-supply from device tree
[    1.334689] vdd_gpu: could not add device link fde60000.gpu err -17
[    1.334705] vdd_gpu: Failed to create debugfs directory
[    1.334720] mali fde60000.gpu: Looking up shadercores-supply from device tree
[    1.334735] mali fde60000.gpu: Looking up shadercores-supply property in node /gpu@fde60000 failed
[    1.334756] mali fde60000.gpu: dev_pm_opp_set_regulators: no regulator (shadercores) found: -19
[    1.334847] mali fde60000.gpu: leakage=7
[    1.334891] mali fde60000.gpu: pvtm = 85400, from nvmem
[    1.335296] mali fde60000.gpu: avs=0
[    1.335318] W : [File] : drivers/gpu/arm/bifrost/platform/rk/mali_kbase_config_rk.c; [Line] : 112; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available.
[    1.335652] mali fde60000.gpu: GPU identified as 0x2 arch 7.4.0 r1p0 status 0
[    1.335738] mali fde60000.gpu: No memory group manager is configured
[    1.336149] mali fde60000.gpu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[    1.336796] mali fde60000.gpu: Probed as mali0
[    1.337264] input: adc-keys as /devices/platform/adc-keys/input/input1
[    1.343190] asoc-simple-card rk809-sound: rk817-hifi <-> fe410000.i2s mapping ok
[    1.345071] rk_iommu fde4b000.iommu: ignoring dependency for device, assuming no driver
[    1.345393]  mmcblk0: p1 p2 p3 p4
[    1.346212] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_pipe-supply from device tree
[    1.346259] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_pipe-supply property in node /power-management@fdd90000/power-controller failed
[    1.346371] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_vi-supply from device tree
[    1.346399] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_vi-supply property in node /power-management@fdd90000/power-controller failed
[    1.347754] RKNPU fde40000.npu: ignoring dependency for device, assuming no driver
[    1.348127] RKNPU fde40000.npu: ignoring dependency for device, assuming no driver
[    1.348584] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    1.349979] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    1.350077] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    1.350093] cfg80211: failed to load regulatory.db
[    1.350936] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_vo-supply from device tree
[    1.350975] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_vo-supply property in node /power-management@fdd90000/power-controller failed
[    1.351805] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '19:06:06', on 'May 21 2024'.
[    1.352092] Mali:
[    1.352093] Mali device driver loaded
[    1.352218] ALSA device list:
[    1.352228]   #0: rockchip,rk809-codec
[    1.352532] Waiting for root device /dev/mmcblk1p3...
[    1.367996] mmc_host mmc2: Bus speed (slot 0) = 25000000Hz (slot req 25000000Hz, actual 25000000HZ div = 0)
[    1.370418] mmc2: new high speed SDIO card at address 0001
[    1.405894] vendor storage:20190527 ret = 0
[    1.438441] devfreq fde60000.gpu: Couldn't update frequency transition information.
[   32.054278] vcc5v0_otg: disabling
