Powering the Q6A via the 5v pin on the 40 pin header
Hey, I am working with the Q6a, now i am intended to power and get data via USB-C PD with a data cable. Now, the USB-C port on the q6a supports only power. I was thinking about using an external board to split the power and data coming from my USB-C cable and powering the SBC via the 5V pin. (via the 12V pin is not preferred due to it being on the other side of the board)
Now I have the following question: Most Radxa 5 V pin on the 40-pin header support it as a way to power the board, but this is not specified for the Radxa Q6a. Can I power the Radxa Q6a via the 5V pin? If so, what is the maximum current it needs/ can handle?
Q6A cannot be powered via 5V pins on 40-pin header.
