I am referring to the following document:
https://docs.radxa.com/en/accessories/storage/penta-sata-hat/penta-for-rpi5
From the documentation, my understanding is that the Penta SATA HAT can supply power to the HDDs as well, and it also says: “Do not use more than one power supply method at the same time.”
I am planning to build a RAID setup with four 3.5-inch HDDs using the Penta SATA HAT.
My planned configuration is:
the 4x 3.5" HDDs are installed in a separate HDD bay/backplane (such as a Rosewill RSV-SATA-Cage-34-type device), and the drives receive power from that bay/backplane
the Raspberry Pi 5 is powered separately using a 5V/5A PSU
the Penta SATA HAT is used only for SATA data connectivity
In this case, is the configuration valid?
I would like to confirm whether using:
separate power for the HDDs, and
separate 5V/5A power for the Raspberry Pi 5
is acceptable when using the Penta SATA HAT, or whether this could cause any power conflict or back-powering issue.
Any clarification would be appreciated.
