I borrowed a friends FTDI friend and got console output. Looks like RockPi is trying to boot from a TFTP image instead of from SD card. It’s never been setup to boot from TFTP by me.
What do I need to do to fix this?
I was able to read info off the SD card from another computer, so it’s not totally fried.
▒DDR Version 1.13 20180801
In
Channel 0: LPDDR4,50MHz
CS = 0
MR0=0x98
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x4D
MR14=0x4D
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
CS = 1
MR0=0x18
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x4D
MR14=0x4D
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=16 Size=2048MB
Channel 1: LPDDR4,50MHz
CS = 0
MR0=0x98
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x4D
MR14=0x4D
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
CS = 1
MR0=0x18
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x4D
MR14=0x4D
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
256B stride
channel 0
CS = 0
MR0=0x98
MR4=0x81
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
CS = 1
MR0=0x18
MR4=0x81
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
channel 1
CS = 0
MR0=0x98
MR4=0x81
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
CS = 1
MR0=0x18
MR4=0x81
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
channel 0 training pass!
channel 1 training pass!
change freq to 400MHz 0,1
channel 0
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
CS = 1
MR0=0x18
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
channel 1
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
CS = 1
MR0=0x18
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
change freq to 800MHz 1,0
ch 0 ddrconfig = 0x101, ddrsize = 0x2020
ch 1 ddrconfig = 0x101, ddrsize = 0x2020
pmugrf_os_reg[2] = 0x3AA1FAA1, stride = 0xD
OUT
U-Boot SPL board init
U-Boot SPL 2017.09-armbian (Jan 27 2019 - 11:14:49)
booted from SD
Trying to boot from MMC2
NOTICE: BL31: v1.3(debug):65aa5ce
NOTICE: BL31: Built : 10:47:37, Jun 19 2018
NOTICE: BL31: Rockchip release version: v1.1
INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1151): pd status 3e
INFO: Entry point address = 0x200000
INFO: SPSR = 0x3c9
U-Boot 2017.09-armbian (Jan 27 2019 - 11:14:49 +0100)
Model: RockPi-4B
DRAM: 3.9 GiB
DCDC_REG1@vdd_center: ; enabling
DCDC_REG2@vdd_cpu_l: ; enabling
DCDC_REG3@vcc_ddr: ; enabling (ret: -38)
DCDC_REG4@vcc_1v8: set 1800000 uV; enabling
LDO_REG1@vcc1v8_dvp: set 1800000 uV; enabling
LDO_REG2@vcc3v0_touch: set 3000000 uV; enabling
LDO_REG3@vcc1v8_pmu: set 1800000 uV; enabling
LDO_REG4@vcc_sd: set 3300000 uV; enabling
LDO_REG5@vcca3v0_codec: set 3000000 uV; enabling
LDO_REG6@vcc_1v5: set 1500000 uV; enabling
LDO_REG7@vcca1v8_codec: set 1800000 uV; enabling
LDO_REG8@vcc_3v0: set 3000000 uV; enabling
SWITCH_REG1@vcc3v3_s3: ; enabling (ret: -38)
SWITCH_REG2@vcc3v3_s0: ; enabling (ret: -38)
vcc1v8-s0@vcc1v8_s0: set 1800000 uV; enabling (ret: -38)
dc-12v@dc_12v: set 12000000 uV; enabling (ret: -38)
vcc-sys@vcc_sys: set 5000000 uV; enabling (ret: -38)
vcc3v3-sys@vcc3v3_sys: set 3300000 uV; enabling (ret: -38)
vcc-phy-regulator@vcc_phy: ; enabling (ret: -38)
vdd-log@vdd_log: ; enabling (ret: -38)
MMC: sdhci@fe330000: 0, dwmmc@fe320000: 1
SF: unrecognized JEDEC id bytes: ff, ff, ff
*** Warning - spi_flash_probe_bus_cs() failed, using default environment
In: serial@ff1a0000
Out: serial@ff1a0000
Err: serial@ff1a0000
Model: RockPi-4B
Net: eth0: ethernet@fe300000
mmc_init: -95, time 20
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1…
2958 bytes read in 23 ms (125 KiB/s)
Executing script at 00500000
Boot script loaded from mmc 1
167 bytes read in 19 ms (7.8 KiB/s)
5981972 bytes read in 665 ms (8.6 MiB/s)
20505088 bytes read in 2203 ms (8.9 MiB/s)
** File not found /boot/dtb/rockchip/rk3399-rockpi4b.dtb **
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
No FDT memory address configured. Please configure
the FDT address via “fdt addr ” command.
Aborting!
2698 bytes read in 49 ms (53.7 KiB/s)
Applying kernel provided DT fixup script (rockchip-fixup.scr)
Executing script at 39000000
Loading init Ramdisk from Legacy Image at 04000000 …
Image Name: uInitrd
Image Type: AArch64 Linux RAMDisk Image (gzip compressed)
Data Size: 5981908 Bytes = 5.7 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum … OK
ERROR: Did not find a cmdline Flattened Device Tree
Could not find a valid device tree
SCRIPT FAILED: continuing…
starting USB…
USB0: USB EHCI 1.00
USB1: USB EHCI 1.00
USB2: Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.10
USB3: Register 2000140 NbrPorts 2
USB XHCI 1.10
scanning bus 0 for devices… 1 USB Device(s) found
scanning bus 1 for devices… 1 USB Device(s) found
scanning bus 2 for devices… 1 USB Device(s) found
scanning bus 3 for devices… 1 USB Device(s) found
scanning usb for storage devices… 0 Storage Device(s) found
Device 0: unknown device
ethernet@fe300000 Waiting for PHY auto negotiation to complete… done
Speed: 1000, full duplex
BOOTP broadcast 1
BOOTP broadcast 2
DHCP client bound to address 192.168.1.4 (253 ms)
*** Warning: no boot file name; using ‘C0A80104.img’
Using ethernet@fe300000 device
TFTP from server 192.168.1.1; our IP address is 192.168.1.4
Filename ‘C0A80104.img’.
Load address: 0x800800
Loading: T T T T T T T T T T
Retry count exceeded; starting again
Retrieving file: pxelinux.cfg/01-9a-f2-4b-05-27-2f
Filename ‘pxelinux.cfg/01-9a-f2-4b-05-27-2f’.
Load address: 0x600000
Retrieving file: pxelinux.cfg/C0A80104
Filename ‘pxelinux.cfg/C0A80104’.
Filename ‘pxelinux.cfg/C0A8010’.
Filename ‘pxelinux.cfg/C0A801’.
Filename ‘pxelinux.cfg/C0A80’.
Filename ‘pxelinux.cfg/C0A8’.
Filename ‘pxelinux.cfg/C0A’.
Filename ‘pxelinux.cfg/C0’.
Filename ‘pxelinux.cfg/C’.
Loading: T
