I have following problem:
After powerup, the LED is Green, no Blue blinking, no boot activity from uSD.
When I connect it to the computer, the RKDevTool says that device is in Mask Mode, even without the Mask button pressed.
Where is the problem?
Your SPI is probably not flashed, and your SD card either has no bootloader on it, or the board is failing to read it.
Try flashing a bootloader image to SPI using RKDevTool.
This means the 5B is alive. When there is nothing to boot, 5B will just go to maskrom mode.
