Hi! Recently we are trying Rock 5C lite headphone jack to play music. We found out popping sound will appear when start the music. Can I know is there any solution to disable the popping sound? Thanks
We will look into this issue.
Could you please tell me which system image you are using and what software you are using to play it?
We are using rock-5c_bookworm_cli_b1.output.img.xz from this link https://github.com/radxa-build/rock-5c/releases
and we are using this command mpg123 -a hw:1,0 xxx.mp3
Okay, have you utilized other tools to test audio playback, and does this phenomenon persist in those instances as well?
I’ve done speaker-test -t wav -c 6 -D plughw:1,0 as well but still the same.
You can try using other types of headphones ,I used the same command to test and did not find any noise issues; there is only a slight noise when it is turned off.
I’ve tried using different speaker and phone jack but still the same. When I change to Rock 5C from Rock 5C lite and seems like much better.
