Hi there,
I want to draw around 70w over the RJ45 connector with PoE++ type 4.
What is the power limit for the rock 5 series boards ?
Can you specify the RJ45 connector which is used ?
thanks
Matt
Hi there,
thanks
Matt
Look into schematics eventually. First tell us what peripherals you have or want to connect including their power consumption characteristics.
You can start here https://docs.radxa.com/en/rock5/rock5b/getting-started/power-supply
I’m confused …
What I want to know is whether the board + rj45 connector can support PoE++ type 4, which is around 1.5 to 2A of current draw over the RJ45 connector and through the 4 PoE pins on the PCB.
What do you mean with ‘the board + rj45 connector’?
It can be ROCK5B for example, or a PoE HAT. Both have detailed specs available in the Documentation section, so maybe look there yourself.
