So I received the 25W PoE hat today and it works! However, the fan placement is not what I was expecting; the fan is not directly over the chip and I should’ve taken a closer look at the placement before ordering but I would’ve ordered anyway.
It took me a bit of searching to find the documentation and instructions on how to setup the fan… (I have not set it up yet)
Too bad this hat does not work with the green fanless case.
Basically, I’ll use the risers to give myself more space between the PoE hat and the board and then I can install some sort of heatsink and fan solution. Has anyone tried something like this with this board? I assume the risers should just work.
Did you enable the overlay as described in the documentation? If everything goes well the fan should only run when CPU temperature is above 60 degrees.
Is there a way to change those? 60deg is not that high but I would like to change several things,
I placed heatsink between hat and board, fit’s perfectly, trying now to tweak right rpm to temperatures
If you want to adjust RPM to temperature you can take a look at Armbian device trees about cooling-maps. They define more trip points with each corresponding to a single fan speed. Right now we basically only have on and off state.
Thanks for this tip,
this fan is 15k rpm and its quite loud. With heatsink board board hits 60deg only on high usage, cooling down imidiately, I need to play with those and have some steps in rpm.
Great, I’ll take a look at that later, fan control map looks reasonable and it’s still user configurable.
what is needed to make it to work on any board? PWM pin setup, temp sensor readout, anything else?
Except controlling fan is there anything else in this board that is still not supported? Any information about power usage?
There’ some static defines presently for pointing to the pwm interface.
You can see in the diff of my fork the changes I made. The original version was managing pwm to the built in-transistor behind the 5v fan pin on the 5b, vs the hat has an actual PWM fan pin.
Main thing to notice is pwm pin and frequency adjustment
Re: power usage… haven’t looked into it… Does the hat have an i2c sensor of sorts to report?
