Hello Igor and thank you for your reply. I have seen you in commits on Github for Armbian and as I’m very new to this, I’m actually speaking to royalty right now
Sry for the late answer, I’ve been sick. So, I remember testing out Armbian a long time ago (12+ months), and at some point with kernel 5.x, it was working. Until it too, broke recently with the new updates. I was almost certain it had to do with the kernel. Because the same thing is happening with @Spooky 's Ubuntu 22 vs 24. The plugin has always been broken on Radxa images, no matter the ‘desktop UI’/gdm or however the big three are called. I mean of course, KDE, XFCE or GNOME. And this is the case for all distros and releases, so nothing there.
It would be of great help to do a, in Python terms, a 'pip freeze > reqs.txt, but for the distros that work, and those that don’t. @kwankiu 's releases have never worked with this specific plugin, no matter desktop nor kernel. So there is something in the development pipeline that goes in a direction that eventually makes my work very cumbersome and limits me to specific OS:s (or rather one, Joshua’s Ubuntu 22.x, which I have other less important bugs with, like sound not working, buggy Chrome making strange rendering, Firefox, which is the alternative, but breaks very often and produce buggy rendering of a page). Next alternative would be the legacy Gnome Armbian. Issue is, and has always been, that the cursor/OS gets stuck every 5 seconds, for a second, until it continues, and does so all the time, which is very disturbing. This issue is fixed on Armbian 6.x, but now the plugin is broken. I love the Radxa images (especially the stability on kernel 6.x b3/latest). Not so much as preferably Armbian, or the learning curve one would get from Arch Linux, but the plugin is broken (even on Arch UEFI).
The plugin in question, is a plugin from the IDE developers of PyCharm (and IntelliJ). The plugin is used to connect the platform hyperskill.org, which is a programming learning platform (the best by my account actually). There’s a rendering software called JCEF, which is some kind of Java thing rendering parts of the IDE with Chromium engine.
I have troubleshooted this for months with Jetbrains’ support, but they tried the only image/OS that the plugin works on which is RaspbianOS (on a RPi5 or lower), and it works, which I can confirm. It also works on the official Ubuntu 22.x but not on the 24.x, just as Joshua’s releases. The support ended at that, leaving me greatly frustrated, having limited myself on my dev comp. (Rock 5B), to one OS, which is Joshua’s Ubuntu 22.04 LTS, which still has many bugs. And my RPi5 (and 4B) are simply too weak to develop on PyCharm.
The question of logs. I know enough to use the commands ‘sudo dmesg -H’. The output does not tell me very much (or rather, what is normal, and what is not). I am aware of sudo journalctl -xe(f). And recently I’ve learned to make use of the serial console through a Raspberry Pi Debug Bridge. I also get a lot of logs from the IDE itself (PyCharm), but that is even more difficult to interpret as experience and knowledge in preferably Java and the IDE itself might be a prerequisite. All of these logs I would be more than happy to provide, and see as a great learning experience in eventually becoming a junior developer in this area (my knowledge is primarily Python and Bash basically). Provide me with what flags and options to use in combination with getting the logs and I will happily provide them, and see it as a learning experience. Jetbrains gave up on me.
Here’s the support ticket URL for some pictures and background to this story.
I want to add that switching the plugin’s task description (which is the one missing in JCEF) to something called Swing, in PyCharm, renders the raw text, but not acceptable enough. It is like watching an html source page without the whissle and bells.
I understand this topic might be too specific. But for me, this is something bigger than that. It is the evolution of ARM64 on a big development environment like PyCharm, on the only device that can pull the weight of a heavy IDE like PyCharm. And in a bigger perspective, there is something really fishy going on, as every major latest OS release is slowly breaking functionality that goes unnoticed, but that has worked in the past. This might pose consequences in other areas later on unimaginable for the time being, but critical in the future.
My URL for the ticket at JetBrains’ support for pictures: https://youtrack.jetbrains.com/issue/EDU-6812
I will register at Armbian as a noobie, in development.
Do you want me to recreate a post there and under which section?
