Issue: Pi Camera v2 Not Working on Radxa Zero 3E (MIPI CSI-2)
Setup
- Board: Radxa Zero 3E
- Camera: Raspberry Pi Camera v2 (IMX219)
- Connection: Using a Raspberry Pi Zero Camera Adapter
- OS: Debian Bullseye
Problem Description
I am trying to capture video/images using the Pi Camera v2 on my Radxa Zero 3E via the MIPI CSI-2 interface, but I encounter errors across different tools.
Errors Encountered
1. Cheese (GUI camera app)
libGL Error: failed to create dri screen
libGL Error: failed to load driver: rockchip
ERROR: XDG_RUNTIME_DIR not set in the environment
2. V4L2-CTL
v4l2-ctl --device /dev/video0 --stream-mmap --stream-count=1 --stream-to=test.raw
- Error:
VIDIOC_REQBUFS error (-1 Invalid argument)
3. GStreamer
gst-launch-1.0 v4l2src device=/dev/video0 ! videoconvert ! jpegenc ! filesink location=capture.jpg
Error: failed to allocate required memory (/GstPipeline:pipeline0/gstv4l2src:v4l2src0)
4. FFmpeg
ffmpeg -f v4l2 -list_formats all -i /dev/video0
- Error:
Not a video capture device /dev/video0: No such device
What I Have Tried
1. Verified Camera Connection
- Running
sudo i2cdetect -y 2shows a new address after plugging in the camera, confirming an I²C connection.
2. Set Overlay for Pi Camera v2
- Used
sudo rsetupto enable the overlay, then rebooted.
3. Checked media-ctl setting - Runing
media-ctl -p -d /dev/media0to check media-ctl setting
Kernel Logs & Errors
1. dmesg | grep -i imx (IMX219 Driver Issues)
[ 14.680900] imx219 2-0010: driver version: 00.01.01
[ 14.681217] imx219 2-0010: Reading register 100 from 10 failed
[ 14.681415] imx219 2-0010: Reading register 100 from 10 failed
[ 14.687969] imx219 2-0010: Error -5 setting default controls
[ 14.688076] imx219: probe of 2-0010 failed with error -5
- The sensor is not responding correctly to I²C register reads, which suggests a communication issue?
2. dmesg | grep -i csi (MIPI CSI-2 Link Errors)
[ 14.804663] rockchip-csi2-dphy0: No link between dphy and sensor
[ 14.805325] rockchip-csi2-dphy0: No link between dphy and sensor
[ 18.502423] rockchip-csi2-dphy0: No link between dphy and sensor
[ 21.367815] rockchip-csi2-dphy0: No link between dphy and sensor
- The camera is not correctly linked to the CSI receiver?
Questions
Has anyone successfully used the Pi Camera v2 on Radxa Zero 3E via MIPI CSI-2? If so, what settings did you use?
Any guidance or suggestions would be greatly appreciated!
