Hi @jack, thanks for that link!
I have updated the configuration following the instructions on the page. After a -planned- next reboot I will revisit this page to update with results. Have a great weekend.
I wonder …
I have the same dismal performance
BTW the comment about ‘real benchmarks’ is only valid id you are looking at ‘real performance’
The dd or hdparm method gives a good feel of what you are measuring.
I have done all the overlay stuff to enable gen-2 mode
I followed the wiki to flash SPI-flash. All went well inckuding a string of ‘wrote block NN’
It does not boot from SPI
There is no /dev/mtd…
Could the ‘no gen-2’ and ‘no SPI flash’ be related and be overlay is not working?
James
I’m glad I’m not the only one then. I’m on the latest kernel from test repo and gen-2 pcie overlay had a near zero impact… So I would speculate it’s to actually working as intended… But I don’t know how to fix it unfortunately.
That won’t do what you think it will do. Because you are writing to a filesystem, what you are really doing, is clearing the disk buffers (kernel), filling the buffers, writing ONLY the overflow, and getting the timing based on that. It doesn’t account for the final sync time, which will make the time lower than it really is. What you should do is more like this;
sync
time (dd if=blah; sync)
And then you take (bytes / real time) to calculate actual speed.
It will be a lot more accurate, but still not good. You really need to do your tests directly onto bare metal. And further, don’t forget to trim the filesystem/disk before running your benchmarks, otherwise the writes will be far slower than they should be since you’re not just writing data, you’re wiping the space clean first.
@fatjoez, I haven’t contacted them, because I can live with the issue at the moment. I was hoping a kernel update might improve the performance, but not so far.
Interestingly, I found an article of someone turning on PCI Gen 2 mode and actually roughly doubling their NVMe performance. I’m going to have another look at that and check if I actually got it right.
