Penta Sata Hat Top Board Issues
I’m trying to build a NAS using RPI5 and Penta sata hat, which has gone quite smoothly. While trying to set up the penta sata hat top board however, I am experiencing 2 issues:
  1. Even if I set a very high temperature (Like 80) for Lv0 in etc/rockpi-penta.conf, the fan never stops. As far as I can see in the documentation, the fan should be off when temperature is below Lv0. It is perhaps good to mention here that when I set a lower tempearture, the fan runs at a higher speed.
  2. The slider function on the key works - I can rotate through the OLED display, but the switch function (double clicking the key) does not work (expected fan turns on/off)
    I am relatively a new to linux and would appreciate any help.
