Can’t see any drives. Can anyone help?
Here is the entire setup:
# flash emmc with balenaEtcher
# info at: https://wiki.radxa.com/Rock4/downloads
# use image:
# https://github.com/radxa/debos-radxa/releases/download/20221109-1007/rockpi-4b-ubuntu-focal-server-arm64-20221109-1331-gpt.img.xz
# boot up, find IP in router ARP table
ssh [email protected]
rock/rock
sudo su
apt-get update
# error:
# W: GPG error: http://apt.radxa.com/focal-stable focal InRelease: The following signatures couldn't be verified because the
# public key is not available: NO_PUBKEY 9B98116C9AA302C7
# E: The repository 'http://apt.radxa.com/focal-stable focal InRelease' is not signed.
# fix the error:
export DISTRO=focal-stable
wget -O - apt.radxa.com/$DISTRO/public.key | sudo apt-key add -
apt-get update
apt-get upgrade
# restart
shutdown -r now
# ssh back in
rock/rock
sudo su
# add the penta sata hat on the Rock Pi 4b
# see: https://wiki.radxa.com/Penta_SATA_HAT
curl -sL https://rock.sh/get-rockpi-penta | sudo -E bash -
# if curl is missing:
sudo apt-get install curl
# possible error:
# Reading state information... Done
# E: Unable to locate package rockpi4b-rk-u-boot-latest
# Traceback (most recent call last):
# File "setup.py", line 3, in <module>
# from setuptools import setup, find_packages
# ModuleNotFoundError: No module named 'setuptools'
# fix with:
sudo apt-get install python3-setuptools
# possible error:
# ModuleNotFoundError: No module named 'pip'
# ModuleNotFoundError: No module named 'ensurepip'
# fix:
sudo apt-get install python3-pip
# run the setup script again
# restart
sudo shutdown -r now
# ssh in
rock/rock
# check status of penta service
sudo systemctl status rockpi-penta.service
# proper output:
# rockpi-penta.service - Rockpi SATA Hat
# Loaded: loaded (/lib/systemd/system/rockpi-penta.service; enabled; vendor preset: enabled)
# Active: active (running) since Tue 2023-09-26 04:34:14 UTC; 16s ago
# Main PID: 456 (python3)
# Tasks: 2 (limit: 4546)
# Memory: 13.0M
# CGroup: /system.slice/rockpi-penta.service
# ├─456 /usr/bin/python3 /usr/bin/rockpi-penta/main.py on
# └─875 /usr/bin/python3 /usr/bin/rockpi-penta/main.py on
# Sep 26 04:34:14 rockpi-4b systemd[1]: Started Rockpi SATA Hat.
# Sep 26 04:34:14 rockpi-4b libmraa[456]: libmraa version v2.1.0 initialised by user 'root' with EUID 0
# Sep 26 04:34:14 rockpi-4b libmraa[456]: gpio: platform doesn't support chardev, falling back to sysfs
# Sep 26 04:34:14 rockpi-4b libmraa[456]: libmraa initialised for platform 'ROCK Pi 4' of type 20
# do this
sudo i2cdetect -y 1
# should see this:
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- UU -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
# at this point you should be able to see drives with
sudo fdisk -l
# or
sudo lsblk
# I can't.
# see the sata controller:
# sudo lspci
# 00:00.0 PCI bridge: Fuzhou Rockchip Electronics Co., Ltd RK3399 PCI Express Root Port
# 01:00.0 SATA controller: JMicron Technology Corp. Device 0585
# to fix error:
sudo su
cd /root
wget https://apt.radxa.com/bionic-stable/pool/main/r/rockpi4b-rk-ubootimg/rockpi4b-rk-ubootimg_2017.09-2700-g70b4cfe057_all.deb
dpkg -i rockpi4b-rk-ubootimg_2017.09-2700-g70b4cfe057_all.deb
y
wget https://apt.radxa.com/bionic-stable/pool/main/r/rockpi4b-rk-u-boot-latest/rockpi4b-rk-u-boot-latest_2017.09-2700-g70b4cfe057_all.deb
dpkg -i rockpi4b-rk-u-boot-latest_2017.09-2700-g70b4cfe057_all.deb
shutdown -r now
# looks good, no errors
# root@rockpi-4b:~# fdisk -l
Disk /dev/ram0: 4 MiB, 4194304 bytes, 8192 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk /dev/mmcblk1: 29.12 GiB, 31268536320 bytes, 61071360 sectors
Disklabel type: gpt
Disk identifier: D6A63D4E-3609-4FE1-8BA9-69D6C9CA2D5E
Device Start End Sectors Size Type
/dev/mmcblk1p1 64 8063 8000 3.9M Microsoft basic data
/dev/mmcblk1p2 16384 24575 8192 4M Microsoft basic data
/dev/mmcblk1p3 24576 32767 8192 4M Microsoft basic data
/dev/mmcblk1p4 32768 1081343 1048576 512M EFI System
/dev/mmcblk1p5 1081344 61069407 59988064 28.6G Linux filesystem
Disk /dev/mmcblk1boot1: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/mmcblk1boot0: 4 MiB, 4194304 bytes, 8192 sectors
# can't see any of the drives plugged in.
root@rockpi-4b:~# lsblk
mmcblk1 179:0 0 29.1G 0 disk
|-mmcblk1p1 179:1 0 3.9M 0 part
|-mmcblk1p2 179:2 0 4M 0 part
|-mmcblk1p3 179:3 0 4M 0 part
|-mmcblk1p4 179:4 0 512M 0 part /boot
`-mmcblk1p5 179:5 0 28.6G 0 part /
mmcblk1boot0 179:32 0 4M 1 disk
mmcblk1boot1 179:64 0 4M 1 disk
mmcblk1rpmb 179:96 0 4M 0 disk
# can't see any drives.
