After swapping the NIC with nvme, the pcie link speed resumed normal, so the problem should be with the card or driver?
sudo lspci -vvv
root@rock-5b:~# sudo lspci -vvv
0000:00:00.0 PCI bridge: Rockchip Electronics Co., Ltd Device 3588 (rev 01) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 149
Bus: primary=00, secondary=01, subordinate=ff, sec-latency=0
I/O behind bridge: 0000f000-00000fff [disabled]
Memory behind bridge: f0200000-f02fffff [size=1M]
Prefetchable memory behind bridge: 00000000fff00000-00000000000fffff [disabled]
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
Expansion ROM at f0300000 [virtual] [disabled] [size=64K]
BridgeCtl: Parity- SERR+ NoISA- VGA- VGA16- MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=375mA PME(D0+,D1+,D2-,D3hot+,D3cold-)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [50] MSI: Enable+ Count=16/32 Maskable+ 64bit+
Address: 00000000fe670040 Data: 0000
Masking: fffffeff Pending: 00000000
Capabilities: [70] Express (v2) Root Port (Slot-), MSI 08
DevCap: MaxPayload 256 bytes, PhantFunc 0
ExtTag+ RBE+
DevCtl: CorrErr- NonFatalErr- FatalErr- UnsupReq-
RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop-
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr- TransPend-
LnkCap: Port #0, Speed 8GT/s, Width x4, ASPM L1, Exit Latency L1 <16us
ClockPM- Surprise- LLActRep+ BwNot- ASPMOptComp+
LnkCtl: ASPM Disabled; RCB 64 bytes, Disabled- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 8GT/s (ok), Width x2 (downgraded)
TrErr- Train- SlotClk+ DLActive+ BWMgmt- ABWMgmt-
RootCap: CRSVisible-
RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna+ CRSVisible-
RootSta: PME ReqID 0000, PMEStatus- PMEPending-
DevCap2: Completion Timeout: Not Supported, TimeoutDis+ NROPrPrP+ LTR+
10BitTagComp- 10BitTagReq- OBFF Via message/WAKE#, ExtFmt+ EETLPPrefix+, MaxEETLPPrefixes 1
EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
FRS- LN System CLS Not Supported, TPHComp- ExtTPHComp- ARIFwd+
AtomicOpsCap: Routing- 32bit- 64bit- 128bitCAS-
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis- LTR+ OBFF Disabled, ARIFwd+
AtomicOpsCtl: ReqEn- EgressBlck-
LnkCap2: Supported Link Speeds: 2.5-8GT/s, Crosslink- Retimer- 2Retimers- DRS-
LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete+ EqualizationPhase1+
EqualizationPhase2+ EqualizationPhase3+ LinkEqualizationRequest-
Retimer- 2Retimers- CrosslinkRes: unsupported
Capabilities: [b0] MSI-X: Enable- Count=128 Masked-
Vector table: BAR=4 offset=00020000
PBA: BAR=4 offset=00028000
Capabilities: [100 v2] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr+ BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr+
AERCap: First Error Pointer: 00, ECRCGenCap+ ECRCGenEn- ECRCChkCap+ ECRCChkEn-
MultHdrRecCap- MultHdrRecEn- TLPPfxPres- HdrLogCap-
HeaderLog: 00000000 00000000 00000000 00000000
RootCmd: CERptEn- NFERptEn- FERptEn-
RootSta: CERcvd- MultCERcvd- UERcvd- MultUERcvd-
FirstFatal- NonFatalMsg- FatalMsg- IntMsg 9
ErrorSrc: ERR_COR: 0000 ERR_FATAL/NONFATAL: 0000
Capabilities: [148 v1] Secondary PCI Express
LnkCtl3: LnkEquIntrruptEn- PerformEqu-
LaneErrStat: 0
Capabilities: [190 v1] L1 PM Substates
L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2- ASPM_L1.1- L1_PM_Substates+
PortCommonModeRestoreTime=10us PortTPowerOnTime=10us
L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1-
T_CommonMode=0us
L1SubCtl2: T_PwrOn=10us
Capabilities: [1d0 v1] Vendor Specific Information: ID=0002 Rev=4 Len=100 <?>
Capabilities: [2d0 v1] Vendor Specific Information: ID=0006 Rev=0 Len=018 <?>
Kernel driver in use: pcieport
0000:01:00.0 Non-Volatile memory controller: Yangtze Memory Technologies Co.,Ltd ZHITAI TiPro7000 (rev 01) (prog-if 02 [NVM Express])
Subsystem: Yangtze Memory Technologies Co.,Ltd ZHITAI TiPro7000
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Latency: 0
Interrupt: pin A routed to IRQ 139
Region 0: Memory at f0200000 (64-bit, non-prefetchable) [size=16K]
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
Address: 0000000000000000 Data: 0000
Masking: 00000000 Pending: 00000000
Capabilities: [70] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 512 bytes, PhantFunc 0, Latency L0s unlimited, L1 unlimited
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 0.000W
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop- FLReset-
DevSta: CorrErr+ NonFatalErr- FatalErr- UnsupReq- AuxPwr+ TransPend-
LnkCap: Port #0, Speed 16GT/s, Width x4, ASPM L1, Exit Latency L1 <64us
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
LnkSta: Speed 8GT/s (downgraded), Width x2 (downgraded)
TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range ABCD, TimeoutDis+ NROPrPrP- LTR+
10BitTagComp+ 10BitTagReq- OBFF Not Supported, ExtFmt- EETLPPrefix-
FRS- TPHComp- ExtTPHComp-
AtomicOpsCap: 32bit- 64bit- 128bitCAS-
LnkCap2: Supported Link Speeds: 2.5-16GT/s, Crosslink- Retimer+ 2Retimers+ DRS-
LnkCtl2: Target Link Speed: 16GT/s, EnterCompliance- SpeedDis-
Retimer- 2Retimers- CrosslinkRes: Upstream Port
Capabilities: [b0] MSI-X: Enable+ Count=66 Masked-
Vector table: BAR=0 offset=00002000
PBA: BAR=0 offset=00003000
Capabilities: [d0] Vital Product Data
pcilib: sysfs_read_vpd: read failed: Input/output error
Not readable
Capabilities: [148 v1] Alternative Routing-ID Interpretation (ARI)
ARICap: MFVC- ACS-, Next Function: 0
ARICtl: MFVC- ACS-, Function Group: 0
Capabilities: [158 v1] Secondary PCI Express
LaneErrStat: 0
Capabilities: [178 v1] Physical Layer 16.0 GT/s <?>
Capabilities: [19c v1] Lane Margining at the Receiver <?>
Capabilities: [1b4 v1] Single Root I/O Virtualization (SR-IOV)
IOVCap: Migration-, Interrupt Message Number: 000
IOVCtl: Enable- Migration- Interrupt- MSE- ARIHierarchy-
IOVSta: Migration-
Initial VFs: 32, Total VFs: 32, Number of VFs: 0, Function Dependency Link: 00
VF offset: 256, stride: 256, Device ID: 5208
Supported Page Size: 00000553, System Page Size: 00000001
Region 0: Memory at 0000000000000000 (64-bit, non-prefetchable)
VF Migration: offset: 00000000, BIR: 0
Capabilities: [1f4 v1] Latency Tolerance Reporting
Max snoop latency: 0ns
Max no snoop latency: 0ns
Capabilities: [1fc v1] L1 PM Substates
L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
T_CommonMode=0us LTR1.2_Threshold=0ns
Capabilities: [20c v1] Vendor Specific Information: ID=0001 Rev=1 Len=038 <?>
Capabilities: [244 v1] Data Link Feature <?>
Kernel driver in use: nvme
0001:10:00.0 PCI bridge: Rockchip Electronics Co., Ltd Device 3588 (rev 01) (prog-if 00 [Normal decode])
Latency: 0
Interrupt: pin A routed to IRQ 140
Bus: primary=10, secondary=11, subordinate=11, sec-latency=0
Memory behind bridge: f1200000-f12fffff [size=1M]
Expansion ROM at f1300000 [virtual] [disabled] [size=64K]
Capabilities: [50] MSI: Enable+ Count=16/32 Maskable- 64bit+
ExtTag- RBE+
LnkCap: Port #0, Speed 8GT/s, Width x2, ASPM L1, Exit Latency L1 <16us
ClockPM- Surprise- LLActRep+ BwNot+ ASPMOptComp+
LnkSta: Speed 8GT/s (ok), Width x2 (ok)
TrErr- Train- SlotClk+ DLActive+ BWMgmt+ ABWMgmt+
RootCap: CRSVisible+
RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna+ CRSVisible+
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis- LTR+ OBFF Disabled, ARIFwd-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr-
LaneErrStat: 0
Capabilities: [180 v1] L1 PM Substates
T_CommonMode=10us
Capabilities: [190 v1] Vendor Specific Information: ID=0002 Rev=4 Len=100 <?>
0001:11:00.0 Non-Volatile memory controller: Yangtze Memory Technologies Co.,Ltd Device 0001 (rev 03) (prog-if 02 [NVM Express])
Subsystem: Yangtze Memory Technologies Co.,Ltd Device 1e49
Latency: 0
Interrupt: pin A routed to IRQ 172
Region 0: Memory at f1200000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [50] MSI: Enable- Count=1/8 Maskable+ 64bit+
DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s unlimited, L1 unlimited
DevSta: CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr+ TransPend-
LnkCap: Port #0, Speed 8GT/s, Width x4, ASPM L1, Exit Latency L1 <8us
ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
10BitTagComp- 10BitTagReq- OBFF Not Supported, ExtFmt- EETLPPrefix-
Capabilities: [b0] MSI-X: Enable+ Count=16 Masked-
PBA: BAR=0 offset=00002100
LaneErrStat: 0
Capabilities: [178 v1] Latency Tolerance Reporting
The nvme disk 1 seems to have some problem when testing, but it should be sufficient to test the pcie slot.
So, what should I do to tune or get the mlx4 to work at 8GT/s pcie gen3 mode… I am really run out of idea…![:dizzy_face: :dizzy_face:](https://forum.radxa.com/images/emoji/twitter/dizzy_face.png?v=9)
