Despite what is written in Radxa documentation (see Clear eMMC or SPI Flash) all my attempt to erase, read or write the SPINOR failed in maskrom mode. The eMMC as the only storage device we can work on.
It was a shame since the windows tool (RKDevTool) has the capability to select the storage device.
rkdeveloptool db rk3588_spl_loader_v1.15.113.bin
# select the SPINOR
rkdeveloptool cs 9
# clear the whole SPINOR device
rkdeveloptool ef
# write an image starting at block 0
rkdeveloptool wl 0 /tmp/spinor_image.bin
the SPINOR is 16MiB size. If you want to use it, you can, for example, store the bootloader (uboot or UEFI) in order to boot an OS somewhere else (eg. NVME).
I never tried to use images provided by Radxa. There were fine when the board was not supported by standard distribution (debian, armbian, ubuntu or whatever). But now, you should use those standard distributions I guess.
the uboot way is for example the armbian official Rock5 Image way. In this case, the uboot image to install on SPINOR is in fact part of the full boot+linux image provided for SD card. For example, if you have the Armbian 24.11.1 Bookworm Minimal (https://www.armbian.com/radxa-rock-5-itx/), from the file Armbian_24.11.1_Rock-5-itx_bookworm_vendor_6.1.75_minimal.img you can extract the bootloader
# empty partition table from 0 to 0x8000
dd if=/dev/zero of=/dev/zero.bin count=64
# bootloader extracted from the 16 first MiB of the SD image
dd if=Armbian_24.11.1_Rock-5-itx_bookworm_vendor_6.1.75_minimal.img \
of=bootloader.bin \
skip=64 count=$((16*1024*1024/512 - 64))
# concatenate to form the SPINOR image
cat zero.bin bootloader.bin > spinor_image.bin
I will soon re-install by radxa board this way on NVME. I should write a small howto.
BTW, it is not necessary to use the SPINOR to boot on NVME. the same SPINOR image produced in the small script described before, can also be flashed in eMMC. But be sure the one you not used is erased (spinor) or full of zeros (eMMC) to be sure of the boot order selected by the ROM.
