Can you recomend a passiv cooling device like the the one shipped with Rock 5B?
Where to order?
Regards
The blue passive heatsink on Rock 5B You mention is too weak for Orion.
As the TDP of CD8081 is about 30W, I guess a 1U aluminium heatsink would suffice for decent cooling in a ventilated case. At least I used such a solution for my Rock 5 ITX and official dimensions seem the same for both boards: 84x84 mm overall size with 75x75 mm for holes, but RK3588 chip draws less power (about 15 W).
Here is my choice for Rock 5 ITX in a Factal Design Node 304 with a very low maximum temperature of the SoC under load:
It perfectly fits on Rock 5 ITX and I think this heatsink would also fit on Orion even if footprint is 85x85 instead of 84x84, but the memory chips will require taller pads for contact.
As most of us received the Orion with the mounted 8420B active cooler (preorder), I may keep this cheap solution for the moment, but if I can, I would choose a copper heatsink instead for passive cooling, maybe this one:
However, be aware that I did not test and that the backplate and/or the heatsink might not fit out-of-the-box on Orion! Footprint is 88x88 mm instead of 84x84 mm⌠So, please only consider this option if You donât mind adapting/cutting the heatsink.
I got this one:
https://streacom.com/products/fc8-fanless-mini-itx-case/
One single-slot, low-profile PCIe slot (network/ low-power RX 6300 GPU), passive heat-pipe CPU cooling.
I ordered the copper version. Iâll tell you if I can install it without problem. From what I measured it should fit very tightly, if it fits
Received the copper heatsink. Itâ s a perfect fit. I am going to test it under load to see how well it keeps it cool.
Glad to hear that it is a perfect fit. Looking forward to your update on the test.
I initially left it passive but I changed my mind. The tempeature under load were stabilizing around 80°C but once reached the cool down was very very long. too long imo. the copper block weighs around 400 grams so it has a lot of inertia. hence it is long to heat it up and even longer to cool down. Eventually, I added some thermal pads on the ram chips and installed a Noctua NF-B9 with a power limiter to keep it quiet. I found that the copper fins are very close to each other and the air tends to get stuck in between so you have to force it through somehow. With this config, temperatures of everything on the board never go over 40-45°C.
Thanks for an informative update. Itâs just too bad that your passive cooling doesnât work for the board. Anyway thanks again.
honestly it was to be expected. The size of the passive coolers of the Steacom FC8 or DB4 Are way bigger and are designed for 45-65W thermal transfer. I am not surprised that this little 400gram block of copper has hard time to fully cool the 35-40W of the SoC.
however, the interesting part here is that this is a very effective cooler once you push air through it, and it is wide enough to cool the ram using thermal pads.
IMO this config looks somehow gorgeous and very silent.
Good to see that the heatsink fits successfully. Indeed, some air flow is always welcome. You are right, pure passive cooling requires sufficient spacing between fins, they have to be tall enough and, very important, an open space above is required to allow natural convection.
In your case, before You installed the fan, the plexiglas seems to entirely cover the heatsink, which is very bad of courseâŚ
As mentioned, I will probably test this heatsink as well, but in a closed case with two low speed 120mm fans at front (intake) and back (exhaust). In case of failure, the Radxa solution is bad, as the heatsink is not supposed to draw the full TDP by itself while this copper heatsink is almost perfect for the purpose, either in an open casing or in a closed case with redundant fans.
Your assumption is incorrect for one reason : The temperatures were still high without the plexiglas. One more thing is that I hoped that putting the heatsink in contact with the plexiglas would force a venturi effect between the fins due to convection, but the fins are too close and too straight and long to actually trigger such an effect.
I had exactly the same experience a few years ago on my LX2: massive copper makes you feel like itâs OK as it doesnât heat quickly. But after some time it gets burning hot and takes ages to cool down. Itâs only inertia, itâs not really cooling. Copper with thin and tight fins only works with a fan on top of it. Without a fan, you need aluminum with sufficiently spaced fins so that free air can flow between them. Usually a good example is how fins are spaced at the rear of audio amps. Usually theyâre thick, long, and about 1cm apart. That gives a good idea of what can work without a fan.
I think that heat sinks like this one (designed for 2U servers) could work much better:
https://www.aliexpress.com/item/1005003615973924.html
Otherwise Iâve had success in other machines with fanned heat sinks where the fan is placed in sandwich between two halves of heat sink, and runs at very low speed, making them totally silent, like this:
https://www.aliexpress.com/item/1005007349640045.html
Theyâre interesting because even a very minimal air flow is sufficient to keep a low temperature, and the rotational noise of the fan is dampened by the fins. However this one requires a real socket to attach to, one needs to find one that attaches to the back plate only.
@willy I did not find the 2U aluminium flavor You propose when searching earlier this year. It seems interesting enough to test, as the fins are here sufficiently spaced and tall. However, it might require some recut as it is a bit larger than the allowed space on Orion.
I will order it and share my results once received, as I am convinced passive cooling is suitable with sufficient case air flow. Of course, I will detail cutting needs if the heatsink cannot be placed âout-of-the-boxâ.
Thank You for the links!
Try to use these links before they disappear (aliexpress is a real pain for this):
https://www.aliexpress.com/item/1005006750690463.html (âAir-cooled 6 Heat Pipe Twin Towers CPU Cooling 90mm Fanâ âŚ)
https://www.aliexpress.com/item/1005007444200990.html (âFanless CPU Cooler 12Cm Fan 6 Copper Heatpipes Fanless Cooling Radiatorâ)
The last one is interesting by the way, though thereâs no indication about how much power it can extract, but I think that 30W will pass through if you just have the caseâs air flow.
Nice sharing. The price seems quite reasonable.
I think these heat pipes make those nice heatsinks too tall for the cases I use. Also, it is not clear to me that they caneasily be attached to the Orion board. So, I have ordered the simple 2U heatsink (refreshed link, same price, same vendor). My intent is to compare the stock Radxa cooler with this simple aluminium passive cooler.
Ah cool, thatâs the one I was no longer able to find there, and yes itâs much better, Iâm tempted as well. For posterity, the description says â2U server CPU cooler radiator Aluminum heatsink for Intel 1150 1151 1155 1156 i3 i5 i7 Industrial computer Passive coolingâ, in case that helps find it again once the link expires!
I received the heatsink some time ago, but do not have much time right now. Also, and this is the main reason, I had trouble installing dual boot with both Radxa-provided images: so Debian image boot seems broken and Fedora 41 does not allow temp measurements out of the box. It means it will take some time for me to restore/solve and compare both cooling solutions in a fair way⌠So âstay tunedâ, as we say in this kind of situation.
Thanks for keeping us updated Yves.
