GPIO number 154 156 157 … and more.
These were work several days ago. I have a simple script to enable the LED:
from periphery import GPIO
import time
RED_PIN = 154
AMBER_PIN = 156
GREEN_PIN = 157
# Open GPIO /dev/gpiochip0 line 10 with input direction
led_red = GPIO(RED_PIN, "out")
# Open GPIO /dev/gpiochip0 line 12 with output direction
led_amber = GPIO(AMBER_PIN, "out")
led_green = GPIO(GREEN_PIN, "out")
while True:
led_red.write(True)
time.sleep(1)
led_red.write(False)
led_amber.write(True)
time.sleep(1)
led_amber.write(False)
led_green.write(True)
time.sleep(1)
led_green.write(False)
Same code, I have try different OS , like Debian and Ubuntu.
My gpioinfo output doesn’t show any PinName, just like this:
gpiochip0 - 32 lines:
line 0: unnamed unused input active-high
line 1: unnamed unused input active-high
line 2: unnamed unused input active-high
line 3: unnamed unused input active-high
line 4: unnamed "host-wakeup" input active-high [used]
line 5: unnamed unused input active-high
line 6: unnamed unused input active-high
line 7: unnamed "cd" input active-low [used]
line 8: unnamed unused input active-high
line 9: unnamed "shutdown" output active-high [used]
line 10: unnamed "reset" output active-low [used]
line 11: unnamed unused input active-high
line 12: unnamed unused input active-high
line 13: unnamed unused input active-high
line 14: unnamed unused input active-high
line 15: unnamed unused input active-high
line 16: unnamed unused input active-high
line 17: unnamed unused input active-high
line 18: unnamed unused input active-high
line 19: unnamed unused input active-high
line 20: unnamed unused input active-high
line 21: unnamed unused input active-high
line 22: unnamed unused input active-high
line 23: unnamed unused input active-high
line 24: unnamed unused input active-high
line 25: unnamed unused input active-high
line 26: unnamed unused input active-high
line 27: unnamed unused input active-high
line 28: unnamed unused input active-high
line 29: unnamed unused input active-high
line 30: unnamed unused input active-high
line 31: unnamed unused input active-high
I am start wondering does my rock pi 4 plus broken.
I start feel this is because of somewhere broken. Because I tired CircuitPython, same behavior.
Some of the Pin just doesn’t work.
example:
[GCC 10.2.1 20210110] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import board
>>> board.
board.ADC_IN0 board.D15 board.D23 board.D31 board.D38 board.MISO board.SCL2 board.SDA6 board.UART4_TX board.pin
board.CS board.D16 board.D24 board.D32 board.D40 board.MOSI board.SCL6 board.SDA7 board.UART_RX board.sys
board.D10 board.D18 board.D27 board.D33 board.D5 board.PWM0 board.SCL7 board.SPI( board.UART_TX
board.D11 board.D19 board.D28 board.D35 board.D7 board.PWM1 board.SCLK board.UART2_RX board.ap_board
board.D12 board.D21 board.D29 board.D36 board.D8 board.SCK board.SDA board.UART2_TX board.board_id
board.D13 board.D22 board.D3 board.D37 board.I2C( board.SCL board.SDA2 board.UART4_RX board.detector
>>> led = digitalio.DigitalInOut(board.D18)
File "<stdin>", line 1, in <module>
NameError: name 'digitalio' is not defined
>>> import digitalio
>>> led.direction = digitalio.Direction.OUTPUT
>>> led.value = True
>>> led = digitalio.DigitalInOut(board.D3)
>>> led = digitalio.DigitalInOut(board.D6)
AttributeError: module 'board' has no attribute 'D6'
>>> led = digitalio.DigitalInOut(board.D16)
>>> led.value = True
File "/usr/local/lib/python3.9/dist-packages/digitalio.py", line 210, in value
raise AttributeError("Not an output")
AttributeError: Not an output
>>> led.value = True
>>> led.value = False
For D3 , it works fine , but for D16(154) D18(156) it just doesn’t work.
Hi guys,
i’ve the same issue but on all GPIO lines… i’can’t do anything… Below my gpioinfo command:
line 4: unnamed unused input active-high
line 7: unnamed unused input active-high
line 9: unnamed unused input active-high
gpiochip1 - 32 lines:
line 3: unnamed "vcc5v0-typec-regulator" output active-high [used]
line 10: unnamed unused input active-high
gpiochip2 - 32 lines:
gpiochip3 - 32 lines:
line 15: unnamed "snps,reset" output active-low [used]
line 25: unnamed "vcc3v3-pcie-regulator" output active-high [used]
line 28: unnamed "user-led1" output active-low [used]
line 29: unnamed "user-led2" output active-high [used]
line 30: unnamed "vbus-host" output active-high [used]
gpiochip4 - 32 lines:
line 27: unnamed unused output active-high
Anyone can help me to understand the issue?.. the board is broken?.. i bought this board for replace rpi 4b…
In my case , it was work several days ago.
In the recent days , I upgraded the kernel to latest 5.10.110-11 with apt command.
I don’t recall I did anything else.
After I found the problem, I downgrade to 5.10.110-8. Still doesn’t work.
Hi @St3fano83, I am wondering did you do the same upgrade?
now i’m on armbian and my kernel version is 5.15.93-rockchip64
I tried armbian as well, but it doesn’t works.
Nasca
7
It looks like we didn’t do libgpiod support before on the board of rock4 series, and i’ll check and fix this issue later.
Maybe worth nothing , I uninstall libgpiod package, still can not light LED through these PINs.
Nasca
9
Is it also uncontrollable with the sysfs interface?
Nasca
10
for example:
echo 154 > /sys/class/gpio/export
echo output > /sys/class/gpio/gpio154/direction
echo 1 > /sys/class/gpio/gpio154/value
echo 0 > /sys/class/gpio/gpio154/value
if it doesn’t work, maybe the hardware broken.
Unfortunately, it doesn’t work. As my testing, all GPIO Pins which in GPIO4 died.
Can I send my board to your company to repair it?
Nasca
12
Are you in China ? If so, you can find our maintenance engineer in the wechat group and ask him to help take a look.
Yes, I do.
Where can I find the QRCode for the wechat group?
Thanks !
I have joined the wechat group which found here: 关于 | Radxa Docs
Also the QQ group.
But I am the only customer in the wechat group and no one answer my question yet.
And I didn’t get approval for the QQ group so far.
Nasca
15
You can @ our team member in the WeChat group.
