Panic in EL3 during Tina OS boot
I tried to burn and boot into the unofficial but publicly listed Tina OS image on my Cubie A5E. I burnt the image onto 8 GB SD card with PhoenixCard with selected “product” option.
During the boot itself it always gets stuck. After some troubleshooting I atteched my serial to USB converter to see the log. Copy of the log is:
[171]HELLO! BOOT0 is starting!
[175]BOOT0 commit : 33d8db429a
[179]periph0 has been enabled
[182]set pll end
[184]PL gpio voltage : 3.3V
[188]PMU: AXP2202
[193]PMU: AXP1530
[198]power mode:33, sys_vol:920
[203]vaild para:1 select dram para0
[206]dram_para[0]:0x4b0
[209]dram_para[1]:0x8
[211]dram_para[2]:0x7070707
[214]dram_para[3]:0xd0d0d0d
[217]dram_para[4]:0xe0e
[220]dram_para[5]:0x84848484
[223]dram_para[6]:0x310a
[226]dram_para[7]:0x10001000
[229]dram_para[8]:0x0
[231]dram_para[9]:0x34
[233]dram_para[10]:0x1b
[236]dram_para[11]:0x33
[239]dram_para[12]:0x3
[241]dram_para[13]:0x0
[243]dram_para[14]:0x0
[246]dram_para[15]:0x4
[248]dram_para[16]:0x72
[251]dram_para[17]:0x0
[253]dram_para[18]:0xe
[256]dram_para[19]:0x0
[258]dram_para[20]:0x0
[261]dram_para[21]:0x26
[263]dram_para[22]:0x80808080
[267]dram_para[23]:0x6060606
[270]dram_para[24]:0x1f0b0503
[273]dram_para[25]:0x0
[275]dram_para[26]:0x3a000000
[278]dram_para[27]:0x802f3333
[282]dram_para[28]:0xc0c0bbbf
[285]dram_para[29]:0x35352f31
[288]dram_para[30]:0xc60
[291]dram_para[31]:0x48484848
[294]board init ok
[317]enable_jtag
[319]card no is 0
[321]sdcard 0 line count 4
[324][mmc]: mmc driver ver 2023-03-24 16:23
[334][mmc]: Wrong media type 0x0
[337][mmc]: Try SD card 0
[349][mmc]: HSSDR52/SDR25 4 bit
[352][mmc]: 50000000 Hz
[354][mmc]: 7600 MB
[357][mmc]: SD/MMC 0 init OK!!!
[369]boot param - magic error
[372]DRAM BOOT DRIVE INFO: V0.67
[376]DRAM_VCC set to 1100 mv
[503]DRAM retraining ten
[629]DRAM retraining ten
[646][AUTO DEBUG]32bit,1 ranks training success!
[675]Soft Training Version: T2.0
[7900][SOFT TRAINING] CLK=1200M Stable memtest pass
[7906]DRAM CLK =1200 MHZ
[7908]DRAM Type =8 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4)
[7919]DRAM SIZE =2048 MBytes, para1 = 310a, para2 = 8000000, tpr13 = 6461
[7949]DRAM simple test OK.
[7952]dram size =2048
[7959]nsi init 2023-2-23
[8081]Loading boot-pkg Succeed(index=0).
[8085]Entry_name = u-boot
[8094]Entry_name = monitor
[8098]Entry_name = scp
[8101]Entry_name = dtb
[8105]mmc not para
[8107]Jump to second Boot.
NOTICE: BL31: v2.5(debug):55b180a27
NOTICE: BL31: Built : 11:09:52, Sep 18 2023
NOTICE: data: ff 10 0 0
NOTICE: hardware error 3
BACKTRACE: START: bl31_platform_setup
0: EL3: 0x480038a4
1: EL3: 0x48003b40
2: EL3: 0x48003a94
3: EL3: 0x480001e0
BACKTRACE: END: bl31_platform_setup
PANIC in EL3.
x30 = 0x0000000048003b4c
x0 = 0x0000000002500000
x1 = 0x0000000000000060
x2 = 0x0000000000000060
x3 = 0x00000000ffffffc8
x4 = 0x0000000000000034
x5 = 0x0000000000000034
x6 = 0x0000000000000004
x7 = 0x0000000000000000
x8 = 0x000000023fffffff
x9 = 0x0000000048010000
x10 = 0x0000000000000000
x11 = 0x0000000048000000
x12 = 0x0000000000000000
x13 = 0x0000000000000000
x14 = 0x0000000000000000
x15 = 0x0000000000000000
x16 = 0x0000000000000000
x17 = 0x0000000000045400
x18 = 0x0000000000000020
x19 = 0x000000004800e3f6
x20 = 0x0000000000000000
x21 = 0x0000000000001890
x22 = 0x0000000000000000
x23 = 0x0000000000000000
x24 = 0x0000000000000000
x25 = 0x0000000000000000
x26 = 0x0000000000000000
x27 = 0x0000000000000000
x28 = 0x0000000000000000
x29 = 0x00000000480112c0
scr_el3 = 0x0000000000000238
sctlr_el3 = 0x0000000030cd183f
cptr_el3 = 0x0000000000000000
tcr_el3 = 0x000000008081351e
daif = 0x00000000000002c0
mair_el3 = 0x00000000004404ff
spsr_el3 = 0x00000000000001cd
elr_el3 = 0x0000000000000000
ttbr0_el3 = 0x000000004803e381
esr_el3 = 0x00000000aaffe3fe
far_el3 = 0x7b5bb51b480ee069
spsr_el1 = 0x00000000000001cd
elr_el1 = 0x0000000000000000
spsr_abt = 0x00000000c84f53ed
spsr_und = 0x00000000800dcdfb
spsr_irq = 0x00000000fe0f69bd
spsr_fiq = 0x00000000f20fffc6
sctlr_el1 = 0x0000000000c50838
actlr_el1 = 0x0000000000000000
cpacr_el1 = 0x0000000000000000
csselr_el1 = 0x0000000000000000
sp_el1 = 0x0000000000000000
esr_el1 = 0x00000000ebde5ffc
ttbr0_el1 = 0x0000fcd1507e79f2
ttbr1_el1 = 0x0000552c576ad230
mair_el1 = 0x44e048e000098aa4
amair_el1 = 0x0000000000000000
tcr_el1 = 0x0000000000000000
tpidr_el1 = 0x58c3af48ffffdefe
tpidr_el0 = 0xfdffffffefffffef
tpidrro_el0 = 0x1791eca1dfdfdfff
par_el1 = 0xff00000048000980
mpidr_el1 = 0x0000000081000000
afsr0_el1 = 0x0000000000000000
afsr1_el1 = 0x0000000000000000
contextidr_el1 = 0x0000000000000000
vbar_el1 = 0x0000000000000000
cntp_ctl_el0 = 0x0000000000000000
cntp_cval_el0 = 0x17410a486c200854
cntv_ctl_el0 = 0x0000000000000000
cntv_cval_el0 = 0xc3e606240ba0c09c
cntkctl_el1 = 0x0000000000000000
sp_el0 = 0x00000000480112c0
isr_el1 = 0x0000000000000000
dacr32_el2 = 0x0000000000000000
ifsr32_el2 = 0x000000000000063f
cpuectlr_el1 = 0x000000002808bc00
icc_hppir0_el1 = 0x00000000000003ff
icc_hppir1_el1 = 0x00000000000003ff
icc_ctlr_el3 = 0x0000000000028400
gicd_ispendr regs (Offsets 0x200-0x278)
Offset Value
0x200: 0x0000000000000000
0x208: 0x0000000000000000
0x210: 0x0000000000000000
0x218: 0x0000000000000000
0x220: 0x0000000000000000
0x228: 0x0000000000000000
0x230: 0x0000000000000000
0x238: 0x0000000000000000
0x240: 0x0000000000000000
0x248: 0x0000000000000000
0x250: 0x0000000000000000
0x258: 0x0000000000000000
0x260: 0x0000000000000000
0x268: 0x0000000000000000
0x270: 0x0000000000000000
0x278: 0x0000000000000000
It says that there is some “panic in EL3”, but since I didn’t built this image I don’t know what to do with it. Do you have any suggestions what migh be causing this error?
BTW if I burn the image with selected “start up” mode in phoenix card, no log is even outputed (but that’s probably unrelated thing).
After some troubleshooting (wrong SD card format - phoenix cards kept crushing) I made flashing using “start up” mode work, but the output log is still the same, still panic in EL3. Used Tina OS as a flashing image.
I also tried flashing provided Android 13 image but the output log is still tha same both in “product” and in “start up” modes - still panic in El3. Because this error is showing in both cases (android an Tina OS) I suspect that the issue is not with the actual image. (Or both images are broken).
For flashing the images I tried several versions of Phoenix card and every version gives the same output at the end (some versions are more sensitive to SD card format). Or is the problem in my flashing software or method?
The other option is that the provided images are built for older revision of Cubie A5E, so on the different board revision that I have those images wont work. Is that a possible scenario?
