Because we disabled the high frequency of the CPU for rk3566-T in the driver. So you can’t make the CPU work in high frequency mode by commanding and modifying dts.
hi, my problem isn’t fully solved: the wifi won’t start after the modification, is there any mode to fix it ?
for clarification: i set the variable soc_is_rk3566t=0, start without any issues a part this
i recompiled radxa kernel sobstituting soc_is_rk3566t=0; in the kernel code but wifi doesn’t work but is you dont need csi consider dietpi or armbian pre-overclocked
