I got Radxa Zero 4gb without headers (that is sad) and with external antenna. But even without antenna it can catch wifi networks. I am curious was it intended?
If the WiFi signal is strong the antenna connector itself will act as the antenna. Or maybe the traces on the board radiate/receive some signal. If you move away from your WiFi router/AP the signal will degrade quickly - but in many cases it will work “well enough” to connect. If you look at the detailed WiFi stats you’ll probably see a lot of error packets.
Put an antenna on it and it will work MUCH better.
Fmm. Impossible to connect to my AP on range more than 5 meters, even if it’s observable.
Thank you for explanation, the topic resolved)
anyone knows wich antenna model i need to buy ??
Hi!
You can buy antenna from official store https://shop.allnetchina.cn/products/dual-frequency-pcb-wifi-antenna-short or find something equal)
