Dear Radxa Community:
The Orion O6N was originally scheduled to be released and shipped on November 25. Due to unforeseen and uncontrollable circumstances, we must postpone the shipment date. Orders will now begin shipping starting from November 30 in batches. We sincerely apologize for the inconvenience this may cause, and we truly appreciate your continued patience, understanding, and support.
Mass production has already begun, and pre-orders for the Orion O6N are now temporarily closed. Once all pre-order units have been shipped, we plan to begin direct in-stock sales in early December. We will announce the exact schedule via Radxaâs official channels.
â Radxa Orion Development Team
As the Orion O6N approaches shipment, weâve received many discussions and questions from the community. To respond to everyoneâs trust and interest, weâve organized the most representative questions into the following Q&A to provide an honest and consolidated update, and to help you better understand the O6N.
1. What are the differences between CD8160, CP8180, and CD8180? Are there any performance differences?
Official response from CiXin (CIX):
âCD8160 was the silkscreen used in early mass production. As PC/server models entered production, all silkscreen numbers were standardized to C*8180. CD8160 is no longer supplied.â
The first batch of Orion O6N will include chips with CD8160 / CP8180 / CD8180 markings, shipped randomly. We have repeatedly confirmed with the CiX team that all three markings are identical in performance and functionality. CiX will gradually phase out the older naming conventions and unify the lineup under the P1 series branding.
2. How does the P1 perform?
Based on current testing and evaluations:
Overall performance is roughly equivalent to an Intel 12th-gen mobile i5
On Arm, it is about 80% of an Apple M1
Approximately 2Ă faster than RK3588
Geekbench 6 reference score: Single-core ~1200, Multi-core ~6800
For an open-source motherboard designed for makers and developers, this level of performance strikes a balanced trade-off between power consumption and cost.
3. Why is the O6N priced so low?
Many people assume that âgood performance + domestic CPU + open-source motherboardâ must mean high cost. In reality, cost is largely designedânot purchased.
From the beginning, the Orion O6N was positioned as a high-value product, achieved through several strategies:
Purposeful hardware design
Some manufacturers lack in-house hardware design capabilities and simply replicate reference designs. Radxa instead evaluates use cases and target users, trimming unnecessary features and optimizing during the design phase to control cost without compromising quality.
Deep understanding of the P1 platform
As the first customer to mass-produce P1 products, we have extensive experience with the Orion O6 series. This allows us to confidently select appropriate domestic components and eliminate redundant circuitry while maintaining stability and reliability.
Refined supply chain management
Although Radxa is a small company, we invest heavily in supply chain optimizationâfrom component selection and alternatives evaluation to production testing and quality controlâensuring a stable cost structure and high yield.
Reasonable profit expectations
Radxa earns modest margins from board sales. We donât rely on slogans or sentiment; instead, we aim to provide makers and developers with a practical, stable, high-value motherboard so you can focus on your creativity and projects.
4. What is the background of CiXin (CIX Tech)?
CiX Technology (Shanghai) Co., Ltd. is a high-end intelligent computing chip company focused on designing general-purpose CPUs compatible with the Arm instruction set. Founded in October 2021, CiX aims to deliver high-performance, low-power CPU cores and chip solutions for global markets and diverse application scenarios.
More information:
5. Will the code be open-source? Will datasheets and TRM be provided?
The Orion O6N software stack will continue using and sharing the existing Radxa Orion O6 repositories, including:
- UEFI firmware
- Linux kernel support
- Debian system build scripts
All of the above will be open-source, allowing users to study and extend the platform.
Regarding P1 documentation, CiXin is planning to release the datasheet and TRM, which are expected to be made public in the near future.
6. Will there be an enclosure?
Yes. A compatible enclosure for the Orion O6N is already available on the pre-order link.
The Orion O6N uses the Nano-ITX (STX) form factor. We will also publish the mechanical specifications, enabling users to design and build custom cases or modify existing ones for unique DIY projects.
7. The O6N has no EC chip. Which functions are affected?
Compared with designs that include an EC (Embedded Controller), certain EC-managed functions on the O6N are now handled directly by the SoC:
Fan Control
- PWM fan connected to the SoC PM module
- Automatically adjusts based on predefined temperature curves
- Linux utilities available for manual control
LED & Power Button
- GPIO signals wired directly to the SoC
- Platform devices defined via ACPI and controlled by the OS
Memory Configuration Detection
- Memory configuration circuitry connects directly to the SoC
- No EC involvement
Power-on Behavior
- Without an EC, the O6N no longer supports configurable âauto power-on after AC restoreâ
- Current hardware behavior: automatically boots when power is connected
Overall, the absence of an EC does not affect daily use or core functionalityâonly certain configurable power behaviors differ from the O6.
8. The O6N doesnât have a 3.5 mm audio jackâdoes this mean no audio output?
Not at all. Due to space constraints on the Nano-ITX (STX) form factor, the O6N does not include a 3.5 mm jack or onboard DAC. However, it still provides full digital audio output:
- Audio via HDMI / DisplayPort, compatible with monitors, TVs, and AV systems
- USB DAC or USB sound cards for high-quality analog 3.5 mm outputâideal for headphones and desktop speakers
9. What is the standby / idle power consumption compared to the O6?
Below are current-stage test results under typical configurations (values may vary with environment; we will continue optimizing and update detailed comparisons later):
Test Environment Includes:
- Display: DP + HDMI
- Cooling: PWM fan
- Networking: dual Ethernet
- USB: 3 Ă USB 3.2 + 3 Ă USB 2.0 with drives, Type-C with USB drive
- Storage: 2 Ă M.2 PCIe SSD
- Wireless: Wi-Fi module
Under load:
- Peak during boot: â 35 W
- System idle: â 19.5 W
- CPU + GPU stress test: â 32 W
- Sleep / Suspend: â 2.3 W
- Shutdown: â 1.5 W
Minimal configuration (all peripherals removed except essentials):
- Peak during boot: â 23 W
- Idle: â 11 W
- Sleep / Suspend: â 0.5 W
- Shutdown: â 0.4 W
We will continue refining power performance and publish updated results on the website and documentation.
These are the current common questions and responses we have compiled from community feedback.
If you have more questions about the Orion O6N, feel free to leave a comment or message us through the official account. We will continue collecting your feedback and respond in future updates.
Thank you to every friend who has followed, pre-ordered, and patiently waited for the O6N. Your support is what brings this open-source motherboard based on the domestic P1 platform to the community and into the hands of real users.
