OpenCL on Q900?
I tried compiling llama.cpp with opencl support to use the Adreno GPU, but it doesn’t work. clinfo shows zero platforms. Do I need to download qualcomm drivers separately? Or is this currently not possible? I’m running the default radxa image radxa-airbox-q900-ubuntu-noble-gnome-t4.
Let me try to reproduce this and hopefully give you a solution soon.
clinfo indeed gets zero platform by default:
radxa@airbox:~$ clinfo
Number of platforms                               0
ICD loader properties
  ICD loader Name                                 OpenCL ICD Loader
  ICD loader Vendor                               OCL Icd free software
  ICD loader Version                              2.3.2
  ICD loader Profile                              OpenCL 3.0
after running sudo apt install qcom-adreno-cl-dev
and then clinfo shows adreno gpu device
clinfo: /lib/aarch64-linux-gnu/libOpenCL.so.1: no version information available (required by clinfo)
Number of platforms                               1
  Platform Name                                   QUALCOMM Snapdragon(TM)
  Platform Vendor                                 QUALCOMM
  Platform Version                                OpenCL 3.0 QUALCOMM build: 0808.11
  Platform Profile                                FULL_PROFILE
  Platform Extensions                             cl_khr_icd
  Platform Extensions with Version                cl_khr_icd                                                       0xc00000 (3.0.0)
  Platform Numeric Version                        0xc00000 (3.0.0)
  Platform Extensions function suffix             QCOM
  Platform Host timer resolution                  0ns
Number of devices                                 1
  Device Name                                     QUALCOMM Adreno(TM) 663
  Device Vendor                                   QUALCOMM
  Device Vendor ID                                0x5143
  Device Version                                  OpenCL 3.0 Adreno(TM) 663
  Device Numeric Version                          0xc00000 (3.0.0)
  Driver Version                                  OpenCL 3.0 QUALCOMM build: 0808.11 Compiler E031.49.02.00
  Device OpenCL C Version                         OpenCL C 3.0 Adreno(TM) 663
  Device OpenCL C all versions                    OpenCL C                                                         0xc00000 (3.0.0)
                                                  OpenCL C                                                         0x800000 (2.0.0)
                                                  OpenCL C                                                         0x402000 (1.2.0)
                                                  OpenCL C                                                         0x401000 (1.1.0)
                                                  OpenCL C                                                         0x400000 (1.0.0)
  Device OpenCL C features                        __opencl_c_3d_image_writes                                       0xc00000 (3.0.0)
                                                  __opencl_c_atomic_order_acq_rel                                  0xc00000 (3.0.0)
                                                  __opencl_c_atomic_order_seq_cst                                  0xc00000 (3.0.0)
                                                  __opencl_c_atomic_scope_device                                   0xc00000 (3.0.0)
                                                  __opencl_c_atomic_scope_all_devices                              0xc00000 (3.0.0)
                                                  __opencl_c_device_enqueue                                        0xc00000 (3.0.0)
                                                  __opencl_c_generic_address_space                                 0xc00000 (3.0.0)
                                                  __opencl_c_images                                                0xc00000 (3.0.0)
                                                  __opencl_c_int64                                                 0xc00000 (3.0.0)
                                                  __opencl_c_pipes                                                 0xc00000 (3.0.0)
                                                  __opencl_c_program_scope_global_variables                        0xc00000 (3.0.0)
                                                  __opencl_c_read_write_images                                     0xc00000 (3.0.0)
                                                  __opencl_c_subgroups                                             0xc00000 (3.0.0)
                                                  __opencl_c_work_group_collective_functions                       0xc00000 (3.0.0)
  Latest conformance test passed                  v2024-05-29-01
  Device Type                                     GPU
  Device Profile                                  FULL_PROFILE
  Device Available                                Yes
  Compiler Available                              Yes
  Linker Available                                Yes
  Max compute units                               3
  Max clock frequency                             1MHz
  Device Partition                                (core)
    Max number of sub-devices                     1
    Supported partition types                     None
    Supported affinity domains                    (n/a)
  Max work item dimensions                        3
  Max work item sizes                             1024x1024x1024
  Max work group size                             1024
  Preferred work group size multiple (device)     64
  Preferred work group size multiple (kernel)     128
  Max sub-groups per work group                   16
Looks good after installing qcom-adreno-cl-dev with llama.cpp backend ops test
radxa@airbox:~/llama.cpp/build$ ./bin/test-backend-ops
ggml_opencl: selected platform: 'QUALCOMM Snapdragon(TM)'
ggml_opencl: device: 'QUALCOMM Adreno(TM) 663 (OpenCL 3.0 Adreno(TM) 663)'
ggml_opencl: OpenCL driver: OpenCL 3.0 QUALCOMM build: 0808.11 Compiler E031.49.02.00
ggml_opencl: vector subgroup broadcast support: true
ggml_opencl: device FP16 support: true
ggml_opencl: mem base addr align: 128
ggml_opencl: max mem alloc size: 256 MB
ggml_opencl: device max workgroup size: 1024
ggml_opencl: SVM coarse grain buffer support: false
ggml_opencl: SVM fine grain buffer support: false
ggml_opencl: SVM fine grain system support: false
ggml_opencl: SVM atomics support: false
ggml_opencl: flattening quantized weights representation as struct of arrays (GGML_OPENCL_SOA_Q)
ggml_opencl: using kernels optimized for Adreno (GGML_OPENCL_USE_ADRENO_KERNELS)
ggml_opencl: loading OpenCL kernels.............................................................................
ggml_opencl: A_q_d buffer size reduced from 311164928 to 268435456 due to device limitations.
ggml_opencl: default device: 'QUALCOMM Adreno(TM) 663 (OpenCL 3.0 Adreno(TM) 663)'
Testing 2 devices
Backend 1/2: GPUOpenCL
  Device description: QUALCOMM Adreno(TM) 663
  Device memory: 0 MB (0 MB free)
  ABS(type=f16,ne_a=[128,2,2,2],v=0): not supported [OpenCL]
  ABS(type=f16,ne_a=[5,7,11,13],v=0): not supported [OpenCL]
  SGN(type=f16,ne_a=[128,2,2,2],v=0): not supported [OpenCL]
  SGN(type=f16,ne_a=[5,7,11,13],v=0): not supported [OpenCL]
  NEG(type=f16,ne_a=[128,2,2,2],v=0): not supported [OpenCL]
  NEG(type=f16,ne_a=[5,7,11,13],v=0): not supported [OpenCL]
  STEP(type=f16,ne_a=[128,2,2,2],v=0): not supported [OpenCL]
  STEP(type=f16,ne_a=[5,7,11,13],v=0): not supported [OpenCL]
  TANH(type=f16,ne_a=[128,2,2,2],v=0): OK
  TANH(type=f16,ne_a=[5,7,11,13],v=0): OK
  ELU(type=f16,ne_a=[128,2,2,2],v=0): not supported [OpenCL]
  ELU(type=f16,ne_a=[5,7,11,13],v=0): not supported [OpenCL]
  RELU(type=f16,ne_a=[128,2,2,2],v=0): not supported [OpenCL]
  RELU(type=f16,ne_a=[5,7,11,13],v=0): not supported [OpenCL]
  SIGMOID(type=f16,ne_a=[128,2,2,2],v=0): OK
  SIGMOID(type=f16,ne_a=[5,7,11,13],v=0): OK
  GELU(type=f16,ne_a=[128,2,2,2],v=0): not supported [OpenCL]
  GELU(type=f16,ne_a=[5,7,11,13],v=0): not supported [OpenCL]
  GELU_QUICK(type=f16,ne_a=[128,2,2,2],v=0): not supported [OpenCL]
  GELU_QUICK(type=f16,ne_a=[5,7,11,13],v=0): not supported [OpenCL]
  SILU(type=f16,ne_a=[128,2,2,2],v=0): not supported [OpenCL]
  SILU(type=f16,ne_a=[5,7,11,13],v=0): not supported [OpenCL]
  HARDSWISH(type=f16,ne_a=[128,2,2,2],v=0): not supported [OpenCL]
  HARDSWISH(type=f16,ne_a=[5,7,11,13],v=0): not supported [OpenCL]
  HARDSIGMOID(type=f16,ne_a=[128,2,2,2],v=0): not supported [OpenCL]
  HARDSIGMOID(type=f16,ne_a=[5,7,11,13],v=0): not supported [OpenCL]
  EXP(type=f16,ne_a=[128,2,2,2],v=0): not supported [OpenCL]
  EXP(type=f16,ne_a=[5,7,11,13],v=0): not supported [OpenCL]
  EXPM1(type=f16,ne_a=[128,2,2,2],v=0): not supported [OpenCL]
  EXPM1(type=f16,ne_a=[5,7,11,13],v=0): not supported [OpenCL]
  SOFTPLUS(type=f16,ne_a=[128,2,2,2],v=0): not supported [OpenCL]
  SOFTPLUS(type=f16,ne_a=[5,7,11,13],v=0): not supported [OpenCL]
  GELU_ERF(type=f16,ne_a=[128,2,2,2],v=0): not supported [OpenCL]
  GELU_ERF(type=f16,ne_a=[5,7,11,13],v=0): not supported [OpenCL]
  FLOOR(type=f16,ne_a=[128,2,2,2],v=0): not supported [OpenCL]
  FLOOR(type=f16,ne_a=[5,7,11,13],v=0): not supported [OpenCL]
  CEIL(type=f16,ne_a=[128,2,2,2],v=0): not supported [OpenCL]
  CEIL(type=f16,ne_a=[5,7,11,13],v=0): not supported [OpenCL]
  ROUND(type=f16,ne_a=[128,2,2,2],v=0): not supported [OpenCL]
  ROUND(type=f16,ne_a=[5,7,11,13],v=0): not supported [OpenCL]
  TRUNC(type=f16,ne_a=[128,2,2,2],v=0): not supported [OpenCL]
  TRUNC(type=f16,ne_a=[5,7,11,13],v=0): not supported [OpenCL]
  ABS(type=f16,ne_a=[128,2,2,2],v=1): not supported [OpenCL]
  ABS(type=f16,ne_a=[5,7,11,13],v=1): not supported [OpenCL]
  SGN(type=f16,ne_a=[128,2,2,2],v=1): not supported [OpenCL]
  SGN(type=f16,ne_a=[5,7,11,13],v=1): not supported [OpenCL]
  NEG(type=f16,ne_a=[128,2,2,2],v=1): not supported [OpenCL]
  NEG(type=f16,ne_a=[5,7,11,13],v=1): not supported [OpenCL]
  STEP(type=f16,ne_a=[128,2,2,2],v=1): not supported [OpenCL]
  STEP(type=f16,ne_a=[5,7,11,13],v=1): not supported [OpenCL]
  TANH(type=f16,ne_a=[128,2,2,2],v=1): OK
  TANH(type=f16,ne_a=[5,7,11,13],v=1): OK
  ELU(type=f16,ne_a=[128,2,2,2],v=1): not supported [OpenCL]
  ELU(type=f16,ne_a=[5,7,11,13],v=1): not supported [OpenCL]
  RELU(type=f16,ne_a=[128,2,2,2],v=1): not supported [OpenCL]
  RELU(type=f16,ne_a=[5,7,11,13],v=1): not supported [OpenCL]
  SIGMOID(type=f16,ne_a=[128,2,2,2],v=1): not supported [OpenCL]
  SIGMOID(type=f16,ne_a=[5,7,11,13],v=1): not supported [OpenCL]
  GELU(type=f16,ne_a=[128,2,2,2],v=1): not supported [OpenCL]
  GELU(type=f16,ne_a=[5,7,11,13],v=1): not supported [OpenCL]
  GELU_QUICK(type=f16,ne_a=[128,2,2,2],v=1): not supported [OpenCL]
  GELU_QUICK(type=f16,ne_a=[5,7,11,13],v=1): not supported [OpenCL]
  SILU(type=f16,ne_a=[128,2,2,2],v=1): not supported [OpenCL]
  SILU(type=f16,ne_a=[5,7,11,13],v=1): not supported [OpenCL]
  HARDSWISH(type=f16,ne_a=[128,2,2,2],v=1): not supported [OpenCL]
  HARDSWISH(type=f16,ne_a=[5,7,11,13],v=1): not supported [OpenCL]
  HARDSIGMOID(type=f16,ne_a=[128,2,2,2],v=1): not supported [OpenCL]
  HARDSIGMOID(type=f16,ne_a=[5,7,11,13],v=1): not supported [OpenCL]
  EXP(type=f16,ne_a=[128,2,2,2],v=1): not supported [OpenCL]
  EXP(type=f16,ne_a=[5,7,11,13],v=1): not supported [OpenCL]
  EXPM1(type=f16,ne_a=[128,2,2,2],v=1): not supported [OpenCL]
  EXPM1(type=f16,ne_a=[5,7,11,13],v=1): not supported [OpenCL]
  SOFTPLUS(type=f16,ne_a=[128,2,2,2],v=1): not supported [OpenCL]
  SOFTPLUS(type=f16,ne_a=[5,7,11,13],v=1): not supported [OpenCL]
  GELU_ERF(type=f16,ne_a=[128,2,2,2],v=1): not supported [OpenCL]
  GELU_ERF(type=f16,ne_a=[5,7,11,13],v=1): not supported [OpenCL]
  FLOOR(type=f16,ne_a=[128,2,2,2],v=1): not supported [OpenCL]
  FLOOR(type=f16,ne_a=[5,7,11,13],v=1): not supported [OpenCL]
  CEIL(type=f16,ne_a=[128,2,2,2],v=1): not supported [OpenCL]
  CEIL(type=f16,ne_a=[5,7,11,13],v=1): not supported [OpenCL]
  ROUND(type=f16,ne_a=[128,2,2,2],v=1): not supported [OpenCL]
  ROUND(type=f16,ne_a=[5,7,11,13],v=1): not supported [OpenCL]
  TRUNC(type=f16,ne_a=[128,2,2,2],v=1): not supported [OpenCL]
  TRUNC(type=f16,ne_a=[5,7,11,13],v=1): not supported [OpenCL]
  ABS(type=f32,ne_a=[128,2,2,2],v=0): not supported [OpenCL]
  ABS(type=f32,ne_a=[5,7,11,13],v=0): not supported [OpenCL]
  SGN(type=f32,ne_a=[128,2,2,2],v=0): not supported [OpenCL]
  SGN(type=f32,ne_a=[5,7,11,13],v=0): not supported [OpenCL]
  NEG(type=f32,ne_a=[128,2,2,2],v=0): not supported [OpenCL]
  NEG(type=f32,ne_a=[5,7,11,13],v=0): not supported [OpenCL]
  STEP(type=f32,ne_a=[128,2,2,2],v=0): not supported [OpenCL]
  STEP(type=f32,ne_a=[5,7,11,13],v=0): not supported [OpenCL]
  TANH(type=f32,ne_a=[128,2,2,2],v=0): OK
  TANH(type=f32,ne_a=[5,7,11,13],v=0): OK
  ELU(type=f32,ne_a=[128,2,2,2],v=0): not supported [OpenCL]
  ELU(type=f32,ne_a=[5,7,11,13],v=0): not supported [OpenCL]
  RELU(type=f32,ne_a=[128,2,2,2],v=0): OK
  RELU(type=f32,ne_a=[5,7,11,13],v=0): OK
  SIGMOID(type=f32,ne_a=[128,2,2,2],v=0): OK
  SIGMOID(type=f32,ne_a=[5,7,11,13],v=0): OK
  GELU(type=f32,ne_a=[128,2,2,2],v=0): OK
  GELU(type=f32,ne_a=[5,7,11,13],v=0): OK
  GELU_QUICK(type=f32,ne_a=[128,2,2,2],v=0): OK
  GELU_QUICK(type=f32,ne_a=[5,7,11,13],v=0): OK
  SILU(type=f32,ne_a=[128,2,2,2],v=0): OK
  SILU(type=f32,ne_a=[5,7,11,13],v=0): OK
This is working now, thanks! Turns out to have been a permission issue: the problem went away when I used sudo.
