This is my current setup.
Base OS: Ubuntu 22.04 (Jammy) headless - installed from the official links from orange pi
Packages installed from ppa:rockchip-linux/ppa and ppa:liujianfeng1994/rockchip-multimedia
mali-g610-firmware rockchip-multimedia-config
Lib Mali: libmali-valhall-g610-g13p0-gbm_1.9-1_arm64.deb (v1.9-1-55611b0) (Installed from https://github.com/tsukumijima/libmali-rockchip/releases)
It works fine when I run clinfo for the first time, but on subsequent reboot it fails.
Here is the dmesg logs after reboot: https://pastebin.com/JefPTVuJ
And the error from clinfo is this: https://pastebin.com/cnQKmCdY
Now weird part is, if I again re-install the same deb file with dpkg, it will then start working fine again. Diff of dmesg post running dpkg again:
[ 280.264215] mali fb000000.gpu: Firmware header version 0.2 not understood
[ 280.264251] mali fb000000.gpu: Firmware initialization failed
[ 691.125169] mali fb000000.gpu: Loading Mali firmware 0x1010000
[ 691.127906] mali fb000000.gpu: Mali firmware git_sha: 221d2b3e5f4cf47df6227ccb24c82c4e4baa986e
And clinfo works correctly now:
arm_release_ver: g13p0-01eac0, rk_so_ver: 10
Number of platforms 2
Platform Name ARM Platform
Platform Vendor ARM
Platform Version OpenCL 3.0 v1.g13p0-01eac0.9113fb3d6cbac82527a272992153edf9
Platform Profile FULL_PROFILE
I have verified that the required files are present in the correct location.
[me@home] ➜ /usr/lib/aarch64-linux-gnu ll | grep mali
drwxr-xr-x - root 26 Jun 11:08 mali
.rw-r--r-- 1.7k root 29 Jul 2020 libmali-hook-injector.a
lrwxrwxrwx 17 root 29 Jul 2020 libmali-hook.so -> libmali-hook.so.1
lrwxrwxrwx 21 root 29 Jul 2020 libmali-hook.so.1 -> libmali-hook.so.1.9.0
.rw-r--r-- 10k root 29 Jul 2020 libmali-hook.so.1.9.0
lrwxrwxrwx 12 root 29 Jul 2020 libmali-valhall-g610-g13p0-gbm.so -> libmali.so.1
lrwxrwxrwx 12 root 29 Jul 2020 libmali.so -> libmali.so.1
lrwxrwxrwx 16 root 29 Jul 2020 libmali.so.1 -> libmali.so.1.9.0
.rw-r--r-- 43M root 29 Jul 2020 libmali.so.1.9.0
[me@home] ➜ lib/firmware ll | grep mali
drwxr-xr-x - root 6 May 19:34 mali_csffw_g15p0
drwxr-xr-x - root 6 May 19:34 mali_csffw_g17p0
drwxr-xr-x - root 6 May 19:34 mali_csffw_g18p0
.rw-r--r-- 274k root 29 Jul 2020 mali_csffw.bin
[me@home] ➜ /etc/OpenCL/vendors cat mali.icd
/usr/lib/aarch64-linux-gnu/libmali.so.1
What am I missing here? I am not able to figure out the reasoning behind failures post reboots.
