BIOS retention is fixed by replacing RTC battery - so it was hw issue
I was unable to reproduce finicky behavior with bios settings, i always exit bios via “continue” button so this was not the case, most likely some combination of parameters change with multiple save via f10 or something ?
Do You have any information on dgpu status for o6n, or any coming bios releases ?
I see some forum members had luck with runing i.ex. polaris gpu on o6 with some older bios (system ready 9.0.0 ?)
But as of now none of available BIOS for o6n seems to work - unable to get gpu working on primary m.2 slot which is using x8 interface, only secondary m.2 , tested all bioses except 1.0.0-2, and from tested gpu only HD4xxx and GT2xx seems to work somewhat ok, all other crushes after driver loading (rx5xx, hd5xxx, hd7xxx, gt5xx)
example errors from dmeseg :
[ 36.223930] amdgpu 0000:91:00.0: amdgpu: Disabling VM faults because of PRT request!
[ 669.170979] amdgpu 0000:91:00.0: amdgpu: Dumping IP State
[ 669.170993] amdgpu 0000:91:00.0: amdgpu: Dumping IP State Completed
[ 669.171131] amdgpu 0000:91:00.0: amdgpu: [drm] AMDGPU device coredump file has been created
[ 669.171136] amdgpu 0000:91:00.0: amdgpu: [drm] Check your /sys/class/drm/card1/device/devcoredump/data
[ 669.181142] amdgpu 0000:91:00.0: amdgpu: ring gfx timeout, signaled seq=58824, emitted seq=58826
[ 669.181149] amdgpu 0000:91:00.0: amdgpu: Process kwin_wayland pid 2081 thread kwin_wayla:cs0 pid 2150
[ 669.181153] amdgpu 0000:91:00.0: amdgpu: GPU reset begin!
[ 673.181313] amdgpu 0000:91:00.0: amdgpu: failed to suspend display audio
[ 673.461189] amdgpu: cp is busy, skip halt cp
[ 673.710214] amdgpu: rlc is busy, skip halt rlc
[ 673.711405] amdgpu 0000:91:00.0: amdgpu: BACO reset
[ 673.879875] amdgpu 0000:91:00.0: amdgpu: GPU reset succeeded, trying to resume
[ 673.880884] [drm] PCIE GART of 256M enabled (table at 0x000000F400F80000).
[ 673.880925] amdgpu 0000:91:00.0: amdgpu: VRAM is lost due to GPU reset!
[ 673.994877] [drm] UVD and UVD ENC initialized successfully.
[ 674.095852] [drm] VCE initialized successfully.
[ 674.108677] amdgpu 0000:91:00.0: amdgpu: GPU reset(1) succeeded!
[ 674.108713] amdgpu 0000:91:00.0: [drm] device wedged, but recovered through reset
[ 674.110387] [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to initialize parser -125!
[ 674.719958] snd_hda_intel 0000:91:00.1: azx_get_response timeout, switching to polling mode: last cmd=0x00872400
[ 674.719976] snd_hda_intel 0000:91:00.1: spurious response 0x0:0x0, last cmd=0x872400
[ 674.719981] snd_hda_intel 0000:91:00.1: spurious response 0x0:0x0, last cmd=0x872400
[ 674.719984] snd_hda_intel 0000:91:00.1: spurious response 0x0:0x0, last cmd=0x872400
[ 674.719987] snd_hda_intel 0000:91:00.1: spurious response 0x0:0x0, last cmd=0x872400
[ 674.719990] snd_hda_intel 0000:91:00.1: spurious response 0x0:0x0, last cmd=0x872400
[ 674.719992] snd_hda_intel 0000:91:00.1: spurious response 0x0:0x0, last cmd=0x872400
[ 674.719995] snd_hda_intel 0000:91:00.1: spurious response 0x0:0x0, last cmd=0x872400
[ 674.719997] snd_hda_intel 0000:91:00.1: spurious response 0x0:0x0, last cmd=0x872400
[ 674.720000] snd_hda_intel 0000:91:00.1: spurious response 0x0:0x0, last cmd=0x872400
[ 674.720002] snd_hda_intel 0000:91:00.1: spurious response 0x0:0x0, last cmd=0x872400
[ 675.722983] snd_hda_intel 0000:91:00.1: No response from codec, disabling MSI: last cmd=0x008f2d00
[ 676.724012] snd_hda_intel 0000:91:00.1: azx_get_response timeout, switching to single_cmd mode: last cmd=0x008f2d00
[ 676.724164] azx_single_wait_for_response: 6 callbacks suppressed
[ 684.531199] amdgpu 0000:91:00.0: amdgpu: Dumping IP State
[ 684.531214] amdgpu 0000:91:00.0: amdgpu: Dumping IP State Completed
[ 684.531242] amdgpu 0000:91:00.0: amdgpu: [drm] AMDGPU device coredump file has been created
[ 684.531247] amdgpu 0000:91:00.0: amdgpu: [drm] Check your /sys/class/drm/card1/device/devcoredump/data
[ 684.531385] amdgpu 0000:91:00.0: amdgpu: ring gfx timeout, but soft recovered
[ 684.685789] fbcon: Taking over console
[ 694.771238] amdgpu 0000:91:00.0: amdgpu: Dumping IP State
[ 694.771250] amdgpu 0000:91:00.0: amdgpu: Dumping IP State Completed
[ 694.771278] amdgpu 0000:91:00.0: amdgpu: [drm] AMDGPU device coredump file has been created
[ 694.771282] amdgpu 0000:91:00.0: amdgpu: [drm] Check your /sys/class/drm/card1/device/devcoredump/data
[ 694.771333] amdgpu 0000:91:00.0: amdgpu: ring gfx timeout, but soft recovered
[ 694.813483] Console: switching to colour frame buffer device 240x67
[ 704.885540] snd_hdac_bus_update_rirb: 160 callbacks suppressed
[ 704.885550] snd_hda_intel 0000:91:00.1: spurious response 0x0:0x0, last cmd=0x570740
[ 704.885556] snd_hda_intel 0000:91:00.1: spurious response 0x600:0x0, last cmd=0x770740
[ 704.885564] snd_hda_intel 0000:91:00.1: spurious response 0x0:0x0, last cmd=0x970740
[ 704.885565] snd_hda_intel 0000:91:00.1: spurious response 0x0:0x0, last cmd=0x970740
[ 704.885567] snd_hda_intel 0000:91:00.1: spurious response 0x0:0x0, last cmd=0x970740
[ 704.885573] snd_hda_intel 0000:91:00.1: spurious response 0x0:0x0, last cmd=0xb70740
[ 704.885589] snd_hda_intel 0000:91:00.1: spurious response 0x0:0x0, last cmd=0x377200
[ 704.885590] snd_hda_intel 0000:91:00.1: spurious response 0x0:0x0, last cmd=0x377200
[ 704.885596] snd_hda_intel 0000:91:00.1: spurious response 0x0:0x0, last cmd=0x378901
[ 704.885611] snd_hda_intel 0000:91:00.1: spurious response 0x0:0x0, last cmd=0x578901
[ 704.885647] arm-smmu-v3 arm-smmu-v3.0.auto: event 0x10 received:
[ 704.885656] arm-smmu-v3 arm-smmu-v3.0.auto: 0x0000910000000010
[ 704.885665] arm-smmu-v3 arm-smmu-v3.0.auto: 0x0000020000000000
[ 704.885673] arm-smmu-v3 arm-smmu-v3.0.auto: 0x0000000000000000
[ 704.885681] arm-smmu-v3 arm-smmu-v3.0.auto: 0x0000000000000000
[ 704.885690] arm-smmu-v3 arm-smmu-v3.0.auto: event: F_TRANSLATION client: 0000:91:00.0 sid: 0x9100 ssid: 0x0 iova: 0x0 ipa: 0x0
[ 704.885692] arm-smmu-v3 arm-smmu-v3.0.auto: unpriv data write s1 "Input address caused fault" stag: 0x0
[ 704.885702] arm-smmu-v3 arm-smmu-v3.0.auto: event 0x10 received:
[ 704.885711] arm-smmu-v3 arm-smmu-v3.0.auto: 0x0000910000000010
[ 704.885712] arm-smmu-v3 arm-smmu-v3.0.auto: 0x0000020000000000
[ 704.885713] arm-smmu-v3 arm-smmu-v3.0.auto: 0x0000000000000000
[ 704.885721] arm-smmu-v3 arm-smmu-v3.0.auto: 0x0000000000000000
[ 704.885729] arm-smmu-v3 arm-smmu-v3.0.auto: event: F_TRANSLATION client: 0000:91:00.0 sid: 0x9100 ssid: 0x0 iova: 0x0 ipa: 0x0
[ 704.885738] arm-smmu-v3 arm-smmu-v3.0.auto: unpriv data write s1 "Input address caused fault" stag: 0x0
[ 704.885739] arm-smmu-v3 arm-smmu-v3.0.auto: event 0x10 received:
[ 704.885747] arm-smmu-v3 arm-smmu-v3.0.auto: 0x0000910000000010
[ 704.885749] arm-smmu-v3 arm-smmu-v3.0.auto: 0x0000020000000000
[ 704.885750] arm-smmu-v3 arm-smmu-v3.0.auto: 0x0000000000000000
[ 704.885757] arm-smmu-v3 arm-smmu-v3.0.auto: 0x0000000000000000
[ 704.885766] arm-smmu-v3 arm-smmu-v3.0.auto: event: F_TRANSLATION client: 0000:91:00.0 sid: 0x9100 ssid: 0x0 iova: 0x0 ipa: 0x0
[ 704.885767] arm-smmu-v3 arm-smmu-v3.0.auto: unpriv data write s1 "Input address caused fault" stag: 0x0
[ 704.885776] arm-smmu-v3 arm-smmu-v3.0.auto: event 0x10 received:
[ 704.885784] arm-smmu-v3 arm-smmu-v3.0.auto: 0x0000910000000010
[ 704.885792] arm-smmu-v3 arm-smmu-v3.0.auto: 0x0000020000000000
[ 704.885793] arm-smmu-v3 arm-smmu-v3.0.auto: 0x0000000000000000
[ 704.885794] arm-smmu-v3 arm-smmu-v3.0.auto: 0x0000000000000000
[ 704.885802] arm-smmu-v3 arm-smmu-v3.0.auto: event: F_TRANSLATION client: 0000:91:00.0 sid: 0x9100 ssid: 0x0 iova: 0x0 ipa: 0x0
[ 704.885804] arm-smmu-v3 arm-smmu-v3.0.auto: unpriv data write s1 "Input address caused fault" stag: 0x0
[ 704.885812] arm-smmu-v3 arm-smmu-v3.0.auto: event 0x10 received:
[ 704.885821] arm-smmu-v3 arm-smmu-v3.0.auto: 0x0000910000000010
[ 704.885822] arm-smmu-v3 arm-smmu-v3.0.auto: 0x0000020000000000
[ 704.885823] arm-smmu-v3 arm-smmu-v3.0.auto: 0x0000000000000000
[ 704.885831] arm-smmu-v3 arm-smmu-v3.0.auto: 0x0000000000000000
[ 704.885832] arm-smmu-v3 arm-smmu-v3.0.auto: event: F_TRANSLATION client: 0000:91:00.0 sid: 0x9100 ssid: 0x0 iova: 0x0 ipa: 0x0
[ 704.885840] arm-smmu-v3 arm-smmu-v3.0.auto: unpriv data write s1 "Input address caused fault" stag: 0x0
[ 704.885849] arm-smmu-v3 arm-smmu-v3.0.auto: event 0x10 received:
[ 704.885856] arm-smmu-v3 arm-smmu-v3.0.auto: 0x0000910000000010
[ 704.885857] arm-smmu-v3 arm-smmu-v3.0.auto: 0x0000020000000000
[ 704.885858] arm-smmu-v3 arm-smmu-v3.0.auto: 0x0000000000000000
[ 704.885859] arm-smmu-v3 arm-smmu-v3.0.auto: 0x0000000000000000
[ 704.885860] arm-smmu-v3 arm-smmu-v3.0.auto: event: F_TRANSLATION client: 0000:91:00.0 sid: 0x9100 ssid: 0x0 iova: 0x0 ipa: 0x0
[ 704.885862] arm-smmu-v3 arm-smmu-v3.0.auto: unpriv data write s1 "Input address caused fault" stag: 0x0
[ 704.885863] arm-smmu-v3 arm-smmu-v3.0.auto: event 0x10 received:
[ 704.885864] arm-smmu-v3 arm-smmu-v3.0.auto: 0x0000910000000010
[ 704.885865] arm-smmu-v3 arm-smmu-v3.0.auto: 0x0000020000000000
[ 704.885866] arm-smmu-v3 arm-smmu-v3.0.auto: 0x0000000000000000
[ 704.885867] arm-smmu-v3 arm-smmu-v3.0.auto: 0x0000000000000000
[ 704.885868] arm-smmu-v3 arm-smmu-v3.0.auto: event: F_TRANSLATION client: 0000:91:00.0 sid: 0x9100 ssid: 0x0 iova: 0x0 ipa: 0x0
[ 704.885869] arm-smmu-v3 arm-smmu-v3.0.auto: unpriv data write s1 "Input address caused fault" stag: 0x0
[ 704.885871] arm-smmu-v3 arm-smmu-v3.0.auto: event 0x10 received:
[ 704.885872] arm-smmu-v3 arm-smmu-v3.0.auto: 0x0000910000000010
[ 704.885873] arm-smmu-v3 arm-smmu-v3.0.auto: 0x0000020000000000
[ 704.885874] arm-smmu-v3 arm-smmu-v3.0.auto: 0x0000000000000000
[ 704.885875] arm-smmu-v3 arm-smmu-v3.0.auto: 0x0000000000000000
[ 704.885876] arm-smmu-v3 arm-smmu-v3.0.auto: event: F_TRANSLATION client: 0000:91:00.0 sid: 0x9100 ssid: 0x0 iova: 0x0 ipa: 0x0
[ 704.885884] arm-smmu-v3 arm-smmu-v3.0.auto: unpriv data write s1 "Input address caused fault" stag: 0x0
[ 704.885885] arm-smmu-v3 arm-smmu-v3.0.auto: event 0x10 received:
[ 704.885886] arm-smmu-v3 arm-smmu-v3.0.auto: 0x0000910000000010
[ 704.885887] arm-smmu-v3 arm-smmu-v3.0.auto: 0x0000020000000000
[ 704.885888] arm-smmu-v3 arm-smmu-v3.0.auto: 0x0000000000000000
[ 704.885889] arm-smmu-v3 arm-smmu-v3.0.auto: 0x0000000000000000
[ 704.885890] arm-smmu-v3 arm-smmu-v3.0.auto: event: F_TRANSLATION client: 0000:91:00.0 sid: 0x9100 ssid: 0x0 iova: 0x0 ipa: 0x0
[ 704.885891] arm-smmu-v3 arm-smmu-v3.0.auto: unpriv data write s1 "Input address caused fault" stag: 0x0
[ 704.885893] arm-smmu-v3 arm-smmu-v3.0.auto: event 0x10 received:
[ 704.885894] arm-smmu-v3 arm-smmu-v3.0.auto: 0x0000910000000010
[ 704.885895] arm-smmu-v3 arm-smmu-v3.0.auto: 0x0000020000000000
[ 704.885896] arm-smmu-v3 arm-smmu-v3.0.auto: 0x0000000000000000
[ 704.885897] arm-smmu-v3 arm-smmu-v3.0.auto: 0x0000000000000000
[ 704.885898] arm-smmu-v3 arm-smmu-v3.0.auto: event: F_TRANSLATION client: 0000:91:00.0 sid: 0x9100 ssid: 0x0 iova: 0x0 ipa: 0x0
[ 704.885899] arm-smmu-v3 arm-smmu-v3.0.auto: unpriv data write s1 "Input address caused fault" stag: 0x0
