Hi
I had my Rock Pi 4c set up so that it boots directly from NVME, now this NVME broke yesterday.
Can I go back to boot from SD card? Or do I have to setup a new NVME card in order to be able to boot?
cheers,
Laci
It should boot with removed nvme and added sd card.
Also You should be able to just burn same image to different nvme (or same if it’s not hardware broken)
thanks, yes, I tested it with a usb drive. I can boot from there.
Is there any hint on how to transfer a running system to USB drive?
I have a Debian GNU/Linux 10 (buster) Version 10.13
running on SD Card and no experiance on how to get USB drive to the system and on how to transfer the existing OS from SD Card to USB drive.
Thanks for support
