NVMe boot issue
Got it issue with SBC boot from NVMe. There are configuration details:
  • Rock 5T SBC w/o eMMC
  • sdcard image: rsdk-r6
  • NVMe: Micron 7450 MAX 800GB NVMe PCIe 4.0
I precisely followed steps that are listed here: Install the system to NVME | Radxa Docs . as a results SBC does not boot up, but got a crash per debug console.
There is a bit of testing has been done with NVMe drive. it works fine i’d say as:
  • it’s detected by OS
  • it’s possible to create partition and filesystem on nvme0n1 device
  • no any errors during IO test. did run random read-write 4k for whole drive. performance is acceptable: ~550 MB/s throughput, ~200k IOPs
Does any direction to get it fixed?
there is what debug output shows:
Device 0: Vendor: 0x1344 Rev: E2MU200  Prod: 241147B2697A
            Type: Hard Disk
            Capacity: 763097.8 MB = 745.2 GB (1562824368 x 512)
... is now current device
Could not find misc partition
ANDROID: reboot reason: "(none)"
Not AVB images, AVB skip
android_image_load_by_partname: Can't find part: boot
Android image load failed
Android boot failed, error -1.
Scanning nvme 0:2...
Scanning nvme 0:3...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
1181 bytes read in 3 ms (383.8 KiB/s)
U-Boot menu
1:      Debian GNU/Linux 12 (bookworm) 6.1.84-8-rk2410
2:      Debian GNU/Linux 12 (bookworm) 6.1.84-8-rk2410 (rescue target)
Enter choice: 1:        Debian GNU/Linux 12 (bookworm) 6.1.84-8-rk2410
Retrieving file: /boot/initrd.img-6.1.84-8-rk2410
20698983 bytes read in 29 ms (680.7 MiB/s)
Retrieving file: /boot/vmlinuz-6.1.84-8-rk2410
35123712 bytes read in 49 ms (683.6 MiB/s)
append: root=UUID=9f01f452-84a8-426a-b759-a6126ff9677e console=ttyFIQ0,1500000n8 quiet splash loglevel=4 rw earlycon consoleblank=0 console=tty1 coherent_pool=2M irqchip.gicv3_pseudo_nmi=0 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 kasan=off
Retrieving file: /usr/lib/linux-image-6.1.84-8-rk2410/rockchip/rk3588-rock-5t.dtb
272878 bytes read in 41 ms (6.3 MiB/s)
Fdt Ramdisk skip relocation
No misc partition
## Flattened Device Tree blob at 0x08300000
   Booting using the fdt blob at 0x08300000
the always on regulator (vcc5v0-host-regulator) should never be disabled!
rockchip_usb2phy_power_off: Failed to set VBus supply
PHY: Failed to power off host-port: -13.
   Using Device Tree in place at 0000000008300000, end 00000000083459ed
## reserved-memory:
  cma: addr=10000000 size=10000000
  ramoops@110000: addr=110000 size=e0000
Adding bank: 0x00200000 - 0xf0000000 (size: 0xefe00000)
Adding bank: 0x100000000 - 0x3fc000000 (size: 0x2fc000000)
Adding bank: 0x3fc500000 - 0x3fff00000 (size: 0x03a00000)
Adding bank: 0x4f0000000 - 0x500000000 (size: 0x10000000)
Total: 8253.128/8266.24 ms
Starting kernel ...
"Synchronous Abort" handler, esr 0x02000000
* Reason:        Exception from an unknown reason
* PC         =   ffffffff1409deb0
* LR         =   0000000000202280
* SP         =   00000000eb9f5120
* ESR_EL2    =   0000000002000000
* Reloc Off  =   00000000eda38000
x0 : 0000000008300000 x1 : 0000000000000000
x2 : 0000000000000000 x3 : 0000000000000000
x4 : 0000000000400000 x5 : 0000000000000001
x6 : 0000000000000008 x7 : 0000000000000001
x8 : 00000000eb9f5298 x9 : 0000010000000000
x10: 00000000ffffffd0 x11: 000000000000000d
x12: 0000000000000006 x13: 000000000001869f
x14: 0000000008300000 x15: 0000000000000002
x16: 00000000edc76814 x17: 0000000000000005
x18: 00000000eb9ffce8 x19: 0000000000000400
x20: 00000000edd5f880 x21: 0000000000000400
x22: 0000000000000003 x23: 00000000eb9f54c8
x24: 00000000eb9f54c8 x25: 00000000edd3d5c0
x26: 0000000000000000 x27: 0000000000000400
x28: 00000000ebc66910 x29: 00000000eb9f5300
Call trace:
  PC:   [< ffffffff1409deb0 >]
  LR:   [< 00202280 >]
Stack:
        [< 0021d2ec >]
        [< 0021cdb0 >]
        [< 00212b98 >]
        [< 00212c74 >]
        [< 0021300c >]
        [< 0022f210 >]
        [< 0021aeec >]
        [< 0021b0a0 >]
        [< 0021a7f0 >]
        [< 0021ada4 >]
        [< 0021b0a0 >]
        [< 0021a7b4 >]
        [< 0022e7d8 >]
        [< 0022f210 >]
        [< 0021aeec >]
        [< 0021ab80 >]
        [< 0021b0a0 >]
        [< 0021a7b4 >]
        [< 0022e7d8 >]
        [< 0022f210 >]
        [< 0021aeec >]
        [< 0021ab80 >]
        [< 0021b0a0 >]
        [< 0021a7b4 >]
        [< 0022e7d8 >]
        [< 0022f210 >]
        [< 0021aeec >]
        [< 0021ab80 >]
        [< 0021ab80 >]
        [< 0021b0a0 >]
        [< 0021a7b4 >]
        [< 0022e7d8 >]
        [< 0022f210 >]
        [< 0021aeec >]
        [< 0021ab80 >]
        [< 0021b0a0 >]
        [< 0021a7b4 >]
        [< 0022e7d8 >]
        [< 0022f210 >]
        [< 0021aeec >]
        [< 0021b0a0 >]
        [< 0021a7b4 >]
        [< 0022e7d8 >]
        [< 0022f210 >]
        [< 0021aeec >]
        [< 0021b0a0 >]
        [< 0021a7f0 >]
        [< 0021ada4 >]
        [< 0021ab80 >]
        [< 0021b0a0 >]
        [< 0021a7b4 >]
        [< 0022e7d8 >]
        [< 0022f210 >]
        [< 0021aeec >]
        [< 0021b0a0 >]
        [< 0021a7b4 >]
        [< 0022e73c >]
        [< 0021b898 >]
        [< 002191ec >]
        [< 0021beac >]
        [< 0029aa34 >]
        [< 0021c0e0 >]
        [< 00201da8 >]
