How is that? t4_4t says “in the cli version the NPU is enabled by default” and you say “it’s not installed at all”?
I just tried the radxa-cm3-rpi-cm4-io_debian_bullseye_kde_b15.img but still no success. It’s still the full 2GB RAM and rsetup does not show any overlay that says something like “enable NPU”.
See below for some specific examples, for reference.
aghost #4 November 3, 2021, 4:38pm
hoko #10 May 10, 2022, 1:06pm
DDR Version V1.10 20210810
In
Starting kernel ...
Armbian 22.05.0-trunk.0053 Jammy ttyS2
rock-3a login:
From immediately after startup (power on) “DDR Version …” to "rock-3a login: ",
Specifically, the log as presented above by “hoko #10 May 10, 2022, 1:06pm”.
Of course, there is no magic tool that will solve everything, so don’t expect transience.
But without it(boot-log), there would be nothing to discuss.
At best, it would end up as a chat-level daily conversation.
I tried the radxa-cm3-io_debian_bullseye_kde_b27.img and there I can select “Enable NPU” in rsetup. But when I reboot I still have the full 2GB RAM (don’t know if that’s supposed to be like this?). The boot log is attached. boot_b27.zip (22.6 KB)
I also tried this OS and removed the “disable NPU overlay”. Then I only have 1,5GB RAM available. But the NPU still does not work. The boot log is the following boot_2023.zip (23.3 KB)
Ok, thank you. So how will this be available? Will there be a new build for the cm3-rpi-cm4-io? The latest one is quite old (13 Oct 2023). Or can I update this one with “apt update”?
I’ve only manged to see the 1.5GB RAM in the old version radxa-cm3-io-debian-bullseye-xfce4-arm64-20230101-1153-gpt.img.xz. For all the new versions I always have the full 2GB RAM available. But even when the 1.5GB RAM are available and I run the NPU demo, I get the error:
E RKNN: [12:50:42.310] failed to open rknpu module, need to insmod rknpu dirver!
E RKNN: [12:50:42.311] failed to open rknn device!
rknn_init fail! ret=-1
With the image radxa-cm3-io_debian_bullseye_kde_b27.img and an enabled “Enable NPU” overlay I still have 2GB RAM available. Although the command sudo systemctl status rknpu2.service says that the service is running but when I execute the demo it still says:
With the radxa-cm3-rpi-cm4-io_debian_bullseye_kde_b15.img and a full update of with apt upgrade I cound not find the “Enable NPU” overlay.
The log you provided shows that a failure has occurred in the “i2c0 communication line.”
This is causing a situation where many nodes that should be detected [ function block: mmc0(sd-cad)/mmc2(bt-wifi)/npu/gpu/ etc… ] are not detected.
In this situation, software approaches such as trying other images are futile.
The first thing to do is to remove this obstacle.
If there is anything connected to connector: “J5” or “J16”, the first thing you should do is disconnect it.
The issue seemed to be the Raspberry IO board. The camera didn’t work with the original Raspberry CM4 either. I changed the IO board and everything works . Sorry for all the hussle and thanks for the support.
