NPU is not working on rock chip cm 3 with debian os
i have enabled the NPU overlay from the rsetup but
i am getting these errors :
sudo dmesg | grep -i npu
[ 4.924102] OF: reserved mem: initialized node rknpu, compatible id shared-dma-pool
[ 5.562021] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up npu-supply from device tree
[ 5.562067] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up npu-supply property in node /power-management@fdd90000/power-controller failed
[ 7.452889] rk_gmac-dwmac fe010000.ethernet: clock input or output? (input).
[ 7.453026] rk_gmac-dwmac fe010000.ethernet: clock input from PHY
[ 7.857937] input: rk805 pwrkey as /devices/platform/fdd40000.i2c/i2c-0/0-0020/rk805-pwrkey/input/input0
[ 7.870515] rkisp_hw fdff0000.rkisp: max input:0x0@0fps
[ 7.893895] rockchip,bus bus-npu: Looking up bus-supply from device tree
[ 7.995932] rockchip,bus bus-npu: Failed to get leakage
[ 7.996080] rockchip,bus bus-npu: pvtm = 89780, from nvmem
[ 7.996104] rockchip,bus bus-npu: pvtm-volt-sel=1
[ 7.996663] rockchip,bus bus-npu: avs=0
[ 8.064304] RKNPU fde40000.npu: Adding to iommu group 0
[ 8.065520] RKNPU fde40000.npu: RKNPU: rknpu iommu is enabled, using iommu mode
[ 8.065639] RKNPU fde40000.npu: Looking up rknpu-supply from device tree
[ 8.066178] RKNPU fde40000.npu: Looking up mem-supply from device tree
[ 8.066212] RKNPU fde40000.npu: Looking up mem-supply property in node /npu@fde40000 failed
[ 8.066530] RKNPU fde40000.npu: can’t request region for resource [mem 0xfde40000-0xfde4ffff]
[ 8.067565] [drm] Initialized rknpu 0.8.8 20230428 for fde40000.npu on minor 1
[ 8.067880] RKNPU fde40000.npu: Looking up rknpu-supply from device tree
[ 8.067928] vdd_gpu: could not add device link fde40000.npu: -EEXIST
[ 8.068229] RKNPU fde40000.npu: leakage=4
[ 8.068279] RKNPU fde40000.npu: pvtm = 89780, from nvmem
[ 8.068296] RKNPU fde40000.npu: pvtm-volt-sel=2
[ 8.069523] RKNPU fde40000.npu: avs=0
[ 8.069844] RKNPU fde40000.npu: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[ 8.070056] RKNPU fde40000.npu: failed to find power_model node
[ 8.070128] RKNPU fde40000.npu: RKNPU: failed to initialize power model
[ 8.070149] RKNPU fde40000.npu: RKNPU: failed to get dynamic-coefficient
[ 8.631478] input: dw_hdmi as /devices/platform/fe0a0000.hdmi/rc/rc0/input1
[ 8.632142] input: hdmi_cec_key as /devices/platform/fe0a0000.hdmi/dw-hdmi-cec.1.auto/input/input2
[ 13.820327] input: headset-keys as /devices/platform/rk817-sound/input/input3
[ 14.097317] input: rockchip-rk817 Headset as /devices/platform/rk817-sound/sound/card1/input4
