Hello… Thank you so much for this…. it still isn’t working but its getting further LOL.
I unxz that file and Balena Etchered it to my SD Card.
Connnected to my A5E I have… My laptop USB serial dongle Rx\Tx\Gnd connected to UART0.
A 256GB eNMC card (ebay, unknown if working as yet) plugged into m.2 socket.
The SD card plugged into the SD socket.
and I am using a USB C mains adapter PSU. Not yet proven if it has enough amps to supply the A5E but I would think so.
I have a HDMI monitor but its not plugged in to the A5E as yet (trying to reduce all the unknowns at the moment trying to get it to boot).
1st power on attempt…
Gets as far as “Hit any key to stop autoboot: 1”… and it hangs. I think it is stuck because I don’t have a USB keyboard plugged in.
2nd attempt (with a USB keyboard plugged in)
Gets as far as “Failed to load ‘/boot/dtb/allwinner/overlay/sun55i-a527-fixup.scr’“… and it hangs.
Here is the full UART0 output –>
U-Boot SPL 2026.01_armbian-2026.01-S127a-Pd40e-Hc6a9-V2b7c-Bd0d2-R448a (Jun 22 2026 - 14:26:24 +0800)
DRAM: 1024 MiB
Trying to boot from MMC1
NOTICE: BL31: v2.13.0(debug):armbian
NOTICE: BL31: Built : 12:53:41, Jun 18 2026
NOTICE: BL31: Detected Allwinner A523 SoC (1890)
NOTICE: BL31: Found U-Boot DTB at 0xa0bd3d8, model: Radxa Cubie A5E
INFO: Configuring SPC Controller
INFO: BL31: Platform setup done
INFO: Maximum SPI INTID supported: 287
INFO: BL31: cortex_a55: CPU workaround for erratum 1530923 was applied
INFO: PSCI: Suspend is unavailable
INFO: Entry point address = 0x4a000000
INFO: SPSR = 0x3c9
U-Boot 2026.01_armbian-2026.01-S127a-Pd40e-Hc6a9-V2b7c-Bd0d2-R448a (Jun 22 2026 - 14:26:24 +0800) Allwinner Technology
CPU: Allwinner A523 (SUN55I)
Model: Radxa Cubie A5E
DRAM: 1 GiB
sunxi_set_gate: (CLK#35) unhandled
Core: 88 devices, 25 uclasses, devicetree: separate
WDT: Not starting watchdog@2050000
MMC: mmc@4020000: 0
Loading Environment from FAT… Unable to use mmc 0:1…
In: serial@2500000
Out: serial@2500000
Err: serial@2500000
Net: eth0: ethernet@4500000
starting USB…
USB EHCI 1.00
USB OHCI 1.0
USB EHCI 1.00
USB OHCI 1.0
ERROR: USB-error: DATAOVERRUN: The amount of data returned by the endpoint exceeded
either the size of the maximum data packet allowed
from the endpoint (found in MaximumPacketSize field
of ED) or the remaining buffer size. (8)
Bus usb@4101000: 1 USB Device(s) found
Bus usb@4101400: 1 USB Device(s) found
Bus usb@4200000: 1 USB Device(s) found
Bus usb@4200400: 2 USB Device(s) found
scanning usb for storage devices… 0 Storage Device(s) found
Hit any key to stop autoboot: 0<0x1b>[K
PCIe: Acquiring resources…
PCIe: All resources acquired. Starting power-on sequence…
PCIe: Toggling external device reset (PERST#)…
PCIe: Hardware power-on sequence successful.
PCIe: Disabling DBI write protection…
PCIe: DBI region: 0x04800000-0x04c80000
PCIe: IO region: 0x21000000-0x22000000
PCIe: MEM region: 0x22000000-0x30000000
PCIe: CFG region: 0x20000000-0x21000000
PCIe: Lanes: 1, Max Speed: Gen2
Link Status: 0x00000004
RDLH_LINK_UP: 0
SMLH_LINK_UP: 0
LINK_SPEED: 0
LINK_WIDTH: 0
RDLH_LINK_UP: 0
SMLH_LINK_UP: 0
LINK_SPEED: 0
LINK_WIDTH: 0
Link Status: 0x00100017
RDLH_LINK_UP: 1
SMLH_LINK_UP: 1
LINK_SPEED: 0
LINK_WIDTH: 1
pcie link up success
PCIe: Link active at Gen2
Device 0: Vendor: 0x1e95 Rev: 25301115 Prod: TW0M3TJT9DH00217008O
Type: Hard Disk
Capacity: 244198.3 MB = 238.4 GB (500118192 x 512)
… is now current device
** No partition table - nvme 0 **
Couldn’t find partition nvme 0:1
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1…
4641 bytes read in 3 ms (1.5 MiB/s)
## Executing script at 4fc00000
U-boot loaded from SD
Boot script loaded from mmc
190 bytes read in 2 ms (92.8 KiB/s)
Load fdt: /boot/dtb/allwinner/sun55i-a527-cubie-a5e.dtb
37462 bytes read in 6 ms (6 MiB/s)
Working FDT set to 4fa00000
So it seems like that OS hangs without a USB keyboard plugged in.
