I am using radxa development board for CM3, and the board has MIPI CSI connector I believe.
and would like to use camera with that connector.
Below are the image of connector which i have for camera and for board.
Could you help how to connect the camera to board, if this is not the correct connector, anyone help me with which connector to get and link for that if any,
I am using IMX219 camera sensor from picamera V.2 version module,
If this is the wrong camera That i am using, let me know which one works fine.
The thing is i am not able to make hardware camera connection to the board itself, as i am using wrong pin for camera and board.
I need help with which camera like in hardware setup.
I have this board with me from wareshare with same pin configuration as radxa cm3.
But before i was able to load the firmware into this cm3 fine, but when i am trying to load the firmware,
i am getting the error as shown in the image.
downloaded the firmware from
and extracted it
installed driver assistant and trying to flash using rkdevtool
tried to flash using TF card, used balenaetcher tool and the same image file as mentioned above,
but its also not working.
once the flash is finished I am seeing the below message and not able to access flash folder.
the RK-dev tool can not flash sd-cards, you need to use etcher or any other tool for that.
The usb-stuff is a known issue, it is not working on most carrier boards, I have made mine work with a special kernel and a little magic, the official way to get it working is this
I have solved the camera issue now, I am facing with SD card issue,
I have loaded the firmware with through RKDevtool,
After loading the firmware i want to access external sd card.
So when I connect with radxa CM3 IO board, its detecting the TF card.
