I followed https://wiki.radxa.com/Rockpi4/dev/Debian to build a Debian-based system image including u-boot, kernel and rootfs. So far everything worked out but after booting the RockPi4b-v1.4 into Openbox I don’t see any Wifi device. ifconfig -a only shows the loopback device lo and eth0. I used the kernel compile script mk-kernel.sh and double checked that make rockchip_linux_defconfig is run. I however did not run make menuconfig afterwards since I’m building in a non-interactive Docker environment. Might that be the source of the problem?
According to uname -a I’m running: Linux linaro-alip 4.4.154-00037-gdb9dfc2cdd25-dirty #1 SMP Fri Jul 16 15:23:07 UTC 2021 aarch64 GNU/Linux.
Please let me know, if you need any further information to diagnose the problem!
I investigated a bit further: The problem does not seem to be kernel config related. I booted the official Debian Buster Desktop (xfce4) image and wifi works.
(rockpi) $ uname -a
Linux rockpi4b 4.4.154-111-rockchip-g39b306a41b2d #1 SMP Wed Jul 8 15:03:52 UTC 2020 aarch64 GNU/Linux
I then checked the kernel config using /proc/config.gz:
What else could possibly have gone wrong during the custom image build?
PS: I can’t find kernel revision 39b306a41b2d from the official Debian image in the radxa/kernel github repo. I wanted to diff it against rev db9dfc2cdd25 of the release-4.4-rockpi4 branch. Any pointers where to find it?
Digging deeper I found this post documenting that for custom kernels the firmware is located in /lib/firmware/ but the kernel needs the firmware files to be placed in /system/etc/firmware/. However this is not the case on my system. fw_bcm43456c5_ag.bin and nvram_ap6256.txt are both there. Though, clm_bcmdhd.blob does not exist on my system. I checked syslog for any firmware related errors but found nothing:
$ dmesg | grep firmware
[ 0.000000] psci: PSCIv1.0 detected in firmware.
$ lsmod
Module Size Used by
There aren’t any kernel modules loaded as well, which seems suspicious.
Switching to the system image with working wifi I get the following:
[...] psci: PSCIv1.0 detected in firmware.
[...] dhd_conf_read_config: Ignore config file /system/etc/firmware/config.txt
[...] Final fw_path=/system/etc/firmware/fw_bcm43456c5_ag.bin
[...] Final nv_path=/system/etc/firmware/nvram_ap6256.txt
[...] Final clm_path=/system/etc/firmware/clm_bcmdhd.blob
[...] Final conf_path=/system/etc/firmware/config.txt
[...] dhd_os_open_image: /system/etc/firmware/fw_bcm43456c5_ag.bin (585884 bytes) open success
[...] dhd_os_open_image: /system/etc/firmware/nvram_ap6256.txt (2099 bytes) open success
[...] dhd_apply_default_clm: Ignore clm file /system/etc/firmware/clm_bcmdhd.blob
$ lsmod
Module Size Used by
bcmdhd 1183744 0
binfmt_misc 20480 1
autofs4 40960 3
Firmware is found and the appropriate kernel modules get loaded.
Searching for bcmdhd.ko on the system running my self-built image does not yield any results. Seems that I’m missing the driver kernel module, right?! Where do I get it from? It’s also suspicious that during boot the system does not even attempt to load any wifi related firmware.
Any pointers on how I may proceed are very appreciated!
