No USB on Waveshare CM4-IO-BASE-A
I’ve tested all images I could find, but I never got the usb-ports of the waveshare board to work with my cm3.
I did put the dto line in uEnv.txt or extlinux.conf (depending on what image I used). I also debugged the boot with my uart adapter and was able to see that uboot loaded the pi-cm4 dto while booting to linux.
I’ve tryed another board, but there was no usb, too.
lsusb shows the usb-controllers, but no device connected, despite me trying several devices on different usb-ports.
Did I miss something ?
How can I make usb work, because without USB the cm3 is just an expensive brick laying around.
Hello, please refer to here
Try the following command
sudo su
echo host > /sys/devices/platform/fe8a0000.usb2-phy/otg_mode
It has no effect.
I have a Waveshare CM4-IO-BASE-B and have been unable to get the CM3 to work at all.
Could I please trouble you to provide the steps you took to get the CM3 to work in the CM4-IO-BASE-A, and which model of the CM3 you were using.
I have a theory… the CM3 without emmc doesn’t work in the CM4-IO-BASE-B, but want to gather more data before I am sure my theory is correct.
Much appreciated.
