No SSH after update?
I have a radxa b5+, running official radxa os, after running these commands:
sudo apt update
sudo apt upgrade -y
sudo apt full-upgrade -y
sudo apt autoremove -y
sudo apt autoclean
sudo reboot
Device does no longer accept SSH, connection timeout, is it fixable or do I have to reinstall the system?
Also does that mean I should not update it?
Only use rsetup for updating
Thanks I also have one more issue, I think the issue was not with update, but there is something wrong with ethernet conenction, it is keep going off. Lights switch off on the back of the radxa after xx minutes, I cannot see it even onm unifi dashboard. Any ideas what might be causing that?
No idea, maybe @radxa would know?
I think this is related to PD charger. I am awaiting for somwthing to set stable 12V and see what is going to happen
If you are using the official image, I saw something similar - the firmware for ethernet is removed during that. If you watch there is some realtek firmware removed
Can you elaborate what do you mean?
In my case Inhave radxa running official firmware for xx amount of time(usualy 10-50 min) and then bum, it’s gone from unifi dashboard etc. I thought that this is because of PD charger that sometimes got issues with the radxa. That’s why I am awaiting that device to stabilise 12V.
But I need to know more about missing realtek drivers from the firmware?
Actually sounds different from what I saw. I was on the rock5b+ using the KDE image, after an update, upgrade and autoremove, the firmware needed for the eth driver had been removed, and didn’t appear. If you are seeing for periods before disappearing sounds like something else
My fault, device was lost always after update, I just never noticed it straight after that as I was busy with other stuff. I followed tips from this thread and it looks like everything is working great.
