No space left on device
I have purchased a Rock pi 4b and a samsung evo 64GB sd card. After booting ubuntu from image , I started installing lxde desktop. But i am getting error .
W: Some index files failed to download. They have been ignored , or old ones used instead
E: IO Error saving source cache
E: The package lists or status file could not be parsed or opened.
I have done df -h it shows
Try Armbian: https://www.armbian.com/rock-pi-4/
https://docs.armbian.com/#what-is-armbian
Try
sudo systemctl enable resize-helper.service
And then reboot.
It is saying failed to enable unit: Unit file /etc/systemd/system/basic.target.wants/resize-helper.service does not exist
It is says failed to enable unit: Unit file /etc/systemd/system/basic.target.wants/resize-helper.service does not exis
Is desktop directly installed using armbian or we have to separately install it??
One more question. Please see the image attached. I am using 64 GB sd card and putted ubuntu server os image. but how come it is not showing this image. I am confused??
I don’t exactly understand your question … but there is no official Ubuntu support.
If you choose desktop image, yes, otherwise: armbian-config → system → enable desktop
Make sure to read a few things and especially 1st boot process. If you don’t create a normal user, there will be no desktop …
parted /dev/mmcblk0 5 64G
resize2fs /dev/mmcblk0p5
