No bluetooth adapter found (Ubuntu 18.04 with ubuntu mate)
I am dsperately trying to get bluetooth running.
I have uninstalled and reinstalled blueman and blueman-gnome, bluez:armhf, bluez-tools - nothing worked.
When I tried to manage bluetooth via terminal, I failed. Can anybody help, please??
Here are some results of the checks I performed
bluetoothctl show says No default controler available.
hcitool doesn’t find any devices
rock@rock:~$ sudo hcitool dev
[sudo] password for rock:
Devices:
rfkill list returns:
rock@rock:~$ sudo rfkill list
0: bt_default: Bluetooth
Soft blocked: no
Hard blocked: no
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
2: brcmfmac-wifi: Wireless LAN
Soft blocked: no
Hard blocked: no
lsusb returns
Bus 006 Device 002: ID 03c3:120e
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 008 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 002: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
rock@rock:~$ systemctl status bluetooth
● bluetooth.service - Bluetooth service
Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset
Active: active (running) since Thu 2019-01-31 23:48:09 CET; 7min ago
Docs: man:bluetoothd(8)
Main PID: 1446 (bluetoothd)
Status: “Running”
Tasks: 1 (limit: 4572)
CGroup: /system.slice/bluetooth.service
└─1446 /usr/lib/bluetooth/bluetoothd
rock@rock:~$ sudo dmesg | grep Blue
[ 1.533211] Bluetooth: Core ver 2.21
[ 1.533949] Bluetooth: HCI device and connection manager initialized
[ 1.534513] Bluetooth: HCI socket layer initialized
[ 1.534949] Bluetooth: L2CAP socket layer initialized
[ 1.535410] Bluetooth: SCO socket layer initialized
[ 3.201308] Bluetooth: Virtual HCI driver ver 1.5
[ 3.201908] Bluetooth: HCI UART driver ver 2.3
[ 3.202309] Bluetooth: HCI UART protocol H4 registered
[ 3.202810] Bluetooth: HCI UART protocol LL registered
[ 3.203266] Bluetooth: HCI UART protocol ATH3K registered
[ 3.482004] Bluetooth: RFCOMM socket layer initialized
[ 3.482051] Bluetooth: RFCOMM ver 1.11
[ 3.482089] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.482107] Bluetooth: HIDP socket layer initialized
I know it’s no consolation but I have Ubuntu 18.04 with Mate also and I have the same problem that you do. I am trying to connect a Microsoft (so not a no-name brand) mouse and keyboard and they are simply not showing up in the Bluetooth manager. No matter what I do, they still aren’t there. Maybe it’s an incompatibility between BT 4.0 and 5.0?
Bluetooth 5 is that it’s completely backwards - compatible with Bluetooth 4.0, 4.1, and 4.2 devices
https://www.electronicdesign.com/embedded-revolution/11-myths-about-bluetooth-5
So maybe not that
The manjaro images work if you install 5.3rc kernel sudo pacman -S linux-aarch64-rc linux-aarch64-rc-headers
With bluetooth that is
