New to radxa - considering purchace
Looking at a Radxa Zero 3w 4gb
Need it to run Android 12 for use with a few apps to monitor BT devices, like Renogy solar DC50s and AOLithium LFP batteries… and a few more things in my RV. Will connect with WWW via a wifi hotspot in the RV.
How much power does this unit draw @ idle?
Will the Android image be damaged if power is cut and restored?
Is the Android image for android TV or is it a tablet version?
Apps I hope to run:
teamviewer Host - to allow me to remotely access the device and control the BlueTooth devices
Renogy DC home - monitor solar and other power aspects of the RV system
Overkill Solar BMS - Monitor and adjust BMS
Ancel BM200 - Monitor RV starter battery directly as well as external under hood ambient temp
ThermoPro Sensor - monitor inside temp and humidity levels.
Thanx for any input on above.
P.S. I was using a Rooted Samsung S7 cell ph with no sim card for this up to recently.
Setup to power off when charge was disconnected and boot up when it was restored.
As it can only run Andy 8 the app support is falling away. It can no longer perform the job…
