I’ve followed the instructions and the troubleshooting FAQ and my new Rock 5B+ (24GB) will not boot. The green light turns on and then stays on. There is no image on the screen.
I have tried:
With Heatsink 6240B (with and without the fan plugged in the header)
With different power sources (Europlug 230V), plugged in the USB-C PD port:
- Samsung EP-TA200 15W Travel Adapter
- Samsung EP-T4511 45W Power Adapter
- Radxa PD 30W
- LG 27UP850K-W.AEU Display built-in charging,
With and without (new 1TB) SSDs in m.2 sockets,
With and without Keyboard and mouse plugged in USB,
With and without microSD containing two different OS images (Radxa 5B+ and Armbian 5B+).
Commands used to flash the (new) microSD:
sudo dd bs=4M if=rock-5b-plus_bookworm_kde_b2.output.img of=/dev/sda1 status=progress oflag=sync
sudo dd bs=4M if=Armbian_24.11.2_Rock-5b-plus_noble_vendor_6.1.75_gnome-kisak_desktop.img of=/dev/sda1 status=progress oflag=sync
Output of fdisk -l after trying to boot the 5B+, same as before:
Disk /dev/sda: 119.21 GiB, 127999672320 bytes, 249999360 sectors
Disk model: STORAGE DEVICE
Units: sectors of 1 * 512 = 512 bytes
Disklabel type: dos
Disk identifier: 0x00000000
Device Boot Start End Sectors Size Id Type
/dev/sda1 32768 249999359 249966592 119.2G 7 HPFS/NTFS/exFAT
I received it new in it’s packaging from arcade.tech.
Is there anything else I should try?
