Hi all, I received a new Rock 3a and a 16Gb emmc yesterday. I seem to be having troubles getting it to accept an image. I also have an unused 256Gb nvme ssd attached.
I have tried using a Rockpi eMMC to uSD board to flash the emmc but fail because the reader with emmc attached comes up in windows device manager as Disk Drive : Mass Storage Device USB Device with’no media’ and a size of 0Mb. The reader card does not have a 1v8 ldo on it… I am waiting on a delivery to try fitting one.
Then I try maskrom mode, I get the 3a into maskrom mode, I try the standard and the specialised helper bin file (even though the MCU is an SCB variant) to no avail, the flash fails straight away with a load error.
You might be thinking a duff emmc?.. trouble is the 3a wont boot with the debian image on as microsd card either… it fails with -
Preformatted text
U-Boot 2017.09-armbian (Feb 17 2023 - 22:34:20 +0000)
Model: Radxa ROCK3 Model A
PreSerial: 2, raw, 0xfe660000
DRAM: 2 GiB
Sysmem: init
Relocation Offset: 7d349000
Relocation fdt: 7b9f69a0 - 7b9fecc8
CR: M/C/I
Using default environment
no mmc device at slot 1
dwmmc@fe2b0000: 1 (SD), dwmmc@fe2c0000: 2, sdhci@fe310000: 0
Bootdev(atags): mmc 1
MMC1: Legacy, 52Mhz
PartType: EFI
No misc partition
boot mode: None
FIT: No boot partition
No resource partition
Failed to load DTB, ret=-19
Failed to get kernel dtb, ret=-19
I2c0 speed: 100000Hz
vsel-gpios- not found! Error: -2
vdd_cpu init 900000 uV
PMIC: RK8090 (on=0x10, off=0x00)
vdd_logic init 900000 uV
vdd_gpu init 900000 uV
vdd_npu init 900000 uV
io-domain: OK
rockchip_set_serialno: could not find efuse/otp device
CLK: (sync kernel. arm: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
apll 816000 KHz
dpll 780000 KHz
gpll 1188000 KHz
cpll 1000000 KHz
npll 1200000 KHz
vpll 24000 KHz
hpll 24000 KHz
ppll 200000 KHz
armclk 816000 KHz
aclk_bus 150000 KHz
pclk_bus 100000 KHz
aclk_top_high 300000 KHz
aclk_top_low 200000 KHz
hclk_top 150000 KHz
pclk_top 100000 KHz
aclk_perimid 300000 KHz
hclk_perimid 150000 KHz
pclk_pmu 100000 KHz
No misc partition
Net: eth1: ethernet@fe010000
Hit key to stop autoboot(‘CTRL+C’): 0
Device 0: Vendor: 0x10ec Rev: VC2S038B Prod: 202304060822
Type: Hard Disk
Capacity: 244198.3 MB = 238.4 GB (500118192 x 512)
… is now current device
** No partition table - nvme 0 **
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1…
Found U-Boot script /boot.scr
reading /boot.scr
3252 bytes read in 2 ms (1.6 MiB/s)
Executing script at 00c00000
Boot script loaded from mmc 1
reading /armbianEnv.txt
151 bytes read in 1 ms (147.5 KiB/s)
reading /uInitrd
DDR Version V1.10 20210810
In
ddrconfig:0
LPDDR4X, 324MHz
BW=32 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=2048MB
tdqss: cs0 dqs0: -48ps, dqs1: -120ps, dqs2: -48ps, dqs3: -144ps,
change to: 324MHz
PHY drv:clk:36,ca:36,DQ:29,odt:60
vrefinner:16%, vrefout:41%
dram drv:40,odt:0
clk skew:0x63
change to: 528MHz
dram drv:40,odt:0
clk skew:0x58
change to: 780MHz
dram drv:40,odt:0
clk skew:0x58
change to: 1560MHz(final freq)
vrefinner:16%, vrefout:22%
dram drv:40,odt:80
vref_ca:00000071
clk skew:0x21
cs 0:
the read training result:
DQS0:0x35, DQS1:0x35, DQS2:0x35, DQS3:0x31,
min :0x10 0xe 0x12 0xd 0x2 0x6 0xa 0x5 , 0xa 0x8 0x1 0x3 0xf 0xd 0xf 0xa ,
0x13 0x12 0x10 0xa 0x5 0x2 0x8 0x5 , 0xd 0x8 0x7 0x1 0x10 0xf 0x10 0x10 ,
mid :0x2c 0x2a 0x2d 0x29 0x1f 0x22 0x27 0x22 ,0x26 0x25 0x1e 0x1e 0x2c 0x29 0x2c 0x27 ,
0x2e 0x2c 0x29 0x26 0x1f 0x1d 0x20 0x21 ,0x28 0x24 0x22 0x1b 0x2c 0x2c 0x2b 0x2b ,
max :0x48 0x47 0x49 0x46 0x3c 0x3f 0x44 0x3f ,0x43 0x42 0x3b 0x3a 0x49 0x46 0x49 0x45 ,
0x49 0x47 0x42 0x42 0x3a 0x39 0x39 0x3d ,0x44 0x41 0x3e 0x36 0x48 0x49 0x47 0x47 ,
range:0x38 0x39 0x37 0x39 0x3a 0x39 0x3a 0x3a ,0x39 0x3a 0x3a 0x37 0x3a 0x39 0x3a 0x3b ,
0x36 0x35 0x32 0x38 0x35 0x37 0x31 0x38 ,0x37 0x39 0x37 0x35 0x38 0x3a 0x37 0x37 ,
the write training result:
DQS0:0x18, DQS1:0xa, DQS2:0x18, DQS3:0x5,
min :0x61 0x65 0x67 0x63 0x57 0x5a 0x5c 0x5e 0x5c ,0x53 0x50 0x4c 0x4a 0x58 0x55 0x54 0x56 0x4f ,
0x5f 0x5e 0x5a 0x59 0x51 0x4e 0x4f 0x55 0x55 ,0x4a 0x46 0x47 0x40 0x4f 0x4f 0x4b 0x54 0x47 ,
mid :0x7c 0x7f 0x81 0x7d 0x71 0x74 0x77 0x76 0x76 ,0x6d 0x6b 0x64 0x64 0x72 0x6f 0x6e 0x6e 0x69 ,
0x7a 0x7a 0x74 0x74 0x6c 0x69 0x6a 0x6f 0x70 ,0x65 0x61 0x60 0x5b 0x6b 0x6a 0x66 0x6d 0x61 ,
max :0x98 0x9a 0x9b 0x97 0x8b 0x8f 0x92 0x8f 0x90 ,0x88 0x86 0x7d 0x7e 0x8c 0x89 0x89 0x87 0x83 ,
0x96 0x96 0x8e 0x8f 0x87 0x84 0x85 0x89 0x8c ,0x81 0x7d 0x79 0x76 0x87 0x86 0x81 0x87 0x7c ,
range:0x37 0x35 0x34 0x34 0x34 0x35 0x36 0x31 0x34 ,0x35 0x36 0x31 0x34 0x34 0x34 0x35 0x31 0x34 ,
0x37 0x38 0x34 0x36 0x36 0x36 0x36 0x34 0x37 ,0x37 0x37 0x32 0x36 0x38 0x37 0x36 0x33 0x35 ,
CA Training result:
cs:0 min :0x49 0x46 0x40 0x3c 0x3e 0x37 0x43 ,0x49 0x43 0x3e 0x37 0x3e 0x37 0x43 ,
cs:0 mid :0x87 0x87 0x7c 0x7b 0x7a 0x77 0x6f ,0x87 0x83 0x7b 0x77 0x7a 0x78 0x70 ,
cs:0 max :0xc5 0xc8 0xb9 0xbb 0xb7 0xb8 0x9c ,0xc5 0xc4 0xb8 0xb7 0xb7 0xb9 0x9d ,
cs:0 range:0x7c 0x82 0x79 0x7f 0x79 0x81 0x59 ,0x7c 0x81 0x7a 0x80 0x79 0x82 0x5a ,
out
U-Boot SPL board init
U-Boot SPL 2017.09-armbian (Feb 17 2023 - 22:34:20)
unknown raw ID phN
unrecognized JEDEC id bytes: 00, 00, 00
Trying to boot from MMC2
Verified-boot: 0
Checking atf-1 0x00040000 … sha256(2f01bd8955…) + OK
Checking uboot 0x00a00000 … sha256(ab53d4f780…) + OK
Checking fdt 0x00b2ecd8 … sha256(4bdde2de3f…) + OK
Checking atf-2 0xfdcc9000 … sha256(f1fecab971…) + OK
Checking atf-3 0xfdcd0000 … sha256(d7aa45eb18…) + OK
Jumping to U-Boot(0x00a00000) via ARM Trusted Firmware(0x00040000)
Total: 237.160 ms
INFO: Preloader serial: 2
NOTICE: BL31: v2.3():v2.3-152-g4e725b15f:cl
NOTICE: BL31: Built : 10:51:13, Jul 15 2021
INFO: pmu v1 is valid
INFO: dfs DDR fsp_param[0].freq_mhz= 1560MHz
INFO: dfs DDR fsp_param[1].freq_mhz= 324MHz
INFO: dfs DDR fsp_param[2].freq_mhz= 528MHz
INFO: dfs DDR fsp_param[3].freq_mhz= 780MHz
INFO: boot cpu mask: 0
INFO: Entry point address = 0xa00000
INFO: SPSR = 0x3c9
Now I am primarily a Windows man so am having a little trouble decyphering that lot but it seems to me to be not seeing the emmc module…what do you guys see? And does the emmc adapter need the 1v8 regulator?
