I bought from allnet china Rock5 B Acrylic Protector with the Fan, but it doesn’t work.
Do you know if I have to enable the fan power somewhere?
Hello!
You have to enable it manually.
Here is link to a guide for Debian distribution:
https://wiki.radxa.com/Rock5/guide/radxa-debian
You will find instructions under the Accessories Configuration - Fan section.
Thanks for putting me in the right direction.
Do I have to put this script in a cronjob? Or there is a better way to config the fan?
Alternatively, you can use this one: https://github.com/pymumu/fan-control-rock5b
Has to be enabled…
I find this fan control by Xiaowei Zhou works better for me an much simpler to implement:
Fan Control:
git clone https://github.com/pymumu/fan-control-rock5b
cd fan-control-rock5b
make package
sudo dpkg -i fan-control*.deb
sudo systemctl enable fan-control
systemctl start fan-control
Or https://github.com/XZhouQD/Rock5B_Naive_Pwm_Fan
If you’re on a fresh OS install, you also need to install git and make:
sudo apt install -y git build-essential
