Hey there, as I understand the type C port should be usable for Data or alternative mode. Before reading on, am i correct?
Apart from that, I am running a ROCK 5 B with a 32gigabyte eMMC module for the OS, 4TB m.2 SSD as main storage. A while ago the main storage ran short so I added a 1TB sATA ssd using usb 3.0->s-ata converter. Now, before I had the m.2 SSD this used to be a no-brainer, it just worked. now I am getting resets on the usb port every now and then:
[18210.076928] scsi host0: uas_eh_device_reset_handler start
[18210.204697] usb 8-1: reset SuperSpeed Gen 1 USB device number 2 using xhci-hcd
[18210.226362] scsi host0: uas_eh_device_reset_handler success
[18261.258129] sd 0:0:0:0: [sda] tag#3 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD IN
[18261.258158] sd 0:0:0:0: [sda] tag#3 CDB: opcode=0x28 28 00 20 34 f9 68 00 01 00 00
[18261.258691] sd 0:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 2 inflight: CMD IN
[18261.258712] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 20 34 fa 68 00 01 00 00
[18263.178165] sd 0:0:0:0: [sda] tag#10 uas_eh_abort_handler 0 uas-tag 3 inflight: CMD OUT
[18263.178196] sd 0:0:0:0: [sda] tag#10 CDB: opcode=0x2a 2a 00 3a 06 37 60 00 00 18 00
I already suspected the SSD to be the culprit, so I changed that(despite being brand new) or the usb-case for the SSD, which I also tried two others. This leaves me to believe that its a power issue.
Since I couldnt find a suitable power supply for the rock 5 I am running the pi on a USB-Type C Dock intended for notebooks. This is arenkforce(I assume this is a store-brand for the supplier I have) type-C dock that takes input from a PD Power Supply and delivers power to the (its intended for notebooks) other USB - Type C Port while also extending out 5 USB 3.0 A Ports, a card reader, ethernet and HDMI. I can confirm this works as I used to use this thing for my notebook.
sensors on the rock 5 B confirms that we are running at 20V @ 2.88 A, so pretty close to the 60 Watts the input power supply(Asus Notebook Charger) delivers.
That means unless i missed something, in certain constellations the m.2 SSD + the USB SSD consume too much power. Considering that the resets occur a lot more frequent when writing to the USB SSD(Which should get close to its power budget) I am fairly confident that the rock is just unable to distribute the power in the needed quantities. Now 99.9% of the time the SSD just resets and then goes on as if nothing happened, but every now and then this aggrevates the jellyfin server running on the rock, so my idea was to plug the ssd in via one of the usb ports of the dock, and have the usb signal passed through along with the power. however no matter where i plug the ssd, its not even being recognized by hte ROCK 5.
Therefore my question: Can the Type C Port be used for data while powering the Rock 5 B?(as it can in maskrom mode)
Do I need to set something up specifically for this to work(kernel option etc)?
