Need debian14 image
gcc 10 ist to old, need a Debian 14 ARM64 image with a modern gcc toolchain (Version 12/13). How to build a Debian 14 ARM64 image, including kernel, bootloader, and root filesystem?
Debian 14 isn’t even released yet.
For ‘images, see here: Index of /images/cloud/forky/daily
How to build? Armbian build framework, you will be the first, so you need to do the work then. Create board config file etc. But gcc12/13 is old as well, deb14/testing is gcc15 ATM. You can run above image/roottree as container as a sort of workaround.
Minimum requirement is gcc 12/13, gcc 15 would be ideal.
The A7S is not supported by Armbian (the board is missing in the list).
Where, how we can start, for get a Debian 14 system that is bootable on a7s
I know, that is why you need to do it. Armbian is a community driven project, so if you want it, you need to do it yourself. You can read how to add a new board on Armbian website, first maybe look if that Allwinner SoC is not already handled in another board, I don’t think so ATM, but check/read yourself.
Else, as indicated, pick a Debian image, just Trixie and run as container. Or upgrade the current rootfs (just the userspace) in-place. That is how it works for cheap and unsupported boards: old/vendor kernel and new userspace. Essentially change sources.list, replace to ‘trixie‘ and dist-upgrade, see debian website how to upgrade to next main release.
He is an old man, no time for builds:-)
You can also install Nix to access latest gcc from nixpkgs. The downside is now you need to learn Nix.
