Hi Guys,
I have been working on trying to get the Rock Pi 4B to work as a Samba server for a NAS.
Has anyone set up something similar to this? I don’t want to boot the pi from the nvme instead I want to use the nvme as the data drive for the NAS. I currently am having issues in getting data transfer speeds above 25mbps. I know for a fact that it is wired to a 1000mb/s switch and have had great success using this exact configuration with a Raspberry pi. I am currently using Armbian. When using ubuntu server the write speed couldn’t even crest 7mbps.
The filesystem is ext4 and I’ve been having this problem with the integrated NVME slot and the usb3.0 ports. I enabled pcie_gen2 in the settings but there was no improvement.
Alright folks, I solved the problem.
It had to do with the way it was being mounted onto my machine. I ended up using cifs-utils and configuring /etc/fstab to auto mount the machine on boot. After that I was able to easily transfer files at 120MB/s.
my iperf3 speeds had previously indicated that I was able to get 120MB/s speed but in testing transferring a file it was getting significantly different results. I’m not sure why the old way of mounting it through smb://ip.addr:/share was so slow but in using fstab to mount it, it all worked out. Hope this helps.
