This is my steps:
1.Install driver by zadig-2.7, choose libusb-win32, success !
2.Earse emmc by RZ_USB_Boot_Helper_V1.0.0.exe, choose rz-udisk-loader.bin, run , success, but won’t appear as a usb storage device; change to radxa-zero-erase-emmc.bin, run, success and found the usb storage device.
3.Flash emmc by Etcher-1.5.76, start in administrator mode, choose image(download fom https://wiki.radxa.com/Zero/downloads), choose usb device from step 3. Flash, success ! (Sometimes mistakes are reported, “Flash Faild !”, " Physical … i/o write …", I can’t remember exactly)
4.Unpluged power, restart, error:
this is log:
G12A:BL:0253b8:61aa2d;FEAT:E0F83180:2000;POC:F;RCY:0;EMMC:0;READ:0;0.0
l2_stage_init 0x01
bl2_stage_init 0x81
hw id: 0x0001 - pwm id 0x00
bl2_stage_init 0xc0
bl2_stage_init 0x02
L0:00000000
L1:00000703
L2:00008067
L3:04000000
S1:00000000
B2:00002000
B1:e0f83180
TE: 136689
Board ID = 2
Set cpu clk to 24M
Set clk81 to 24M
CPU clk: 1200 MHz
Set clk81 to 166.6M
eMMC boot @ 0
sw8 s
board id: 2
Load FIP HDR from eMMC, src: 0x00010200, des: 0xfffd0000, size: 0x00004000, part: 0
fw parse done
Load ddrfw from eMMC, src: 0x00060200, des: 0xfffd0000, size: 0x0000c000, part: 0
Load ddrfw from eMMC, src: 0x00038200, des: 0xfffd0000, size: 0x00004000, part: 0
PIEI prepare done
fastboot data load
00000000
emmc switch 1 ok
00000000
emmc switch 2 ok
fastboot data verify
verify result: 265
LPDDR4 probe
ddr clk to 792MHz
Load ddrfw from eMMC, src: 0x0003c200, des: 0xfffd0000, size: 0x0000c000, part: 0
00000000
emmc switch 0 ok
dmc_version 0000
Check phy result
INFO : End of CA training
INFO : End of initialization
Check phy result
Check phy result
1D training succeed
Load ddrfw from eMMC, src: 0x00048200, des: 0xfffd0000, size: 0x0000c000, part: 0
Check phy result
channel==0
RxClkDly_Margin_A0==236 ps 12
TxDqDly_Margin_A0==236 ps 12
RxClkDly_Margin_A1==236 ps 12
TxDqDly_Margin_A1==236 ps 12
TrainedVREFDQ_A0==74
TrainedVREFDQ_A1==74
VrefDac_Margin_A0==24
DeviceVref_Margin_A0==40
VrefDac_Margin_A1==22
DeviceVref_Margin_A1==40
channel==1
RxClkDly_Margin_A0==216 ps 11
TxDqDly_Margin_A0==216 ps 11
TxDqDly_Margin_A1==216 ps 11
VrefDac_Margin_A0==22
VrefDac_Margin_A1==24
soc_vref_reg_value 0x 00000015 00000014 00000014 00000015 00000013 00000013 00000015 00000015 00000014 00000016 00000014 00000 013 00000013 00000015 00000014 00000015 00000015 00000015 00000014 00000016 00000016 00000014 00000017 00000015 00000017 00000 014 00000016 00000017 00000015 00000012 00000012 00000015 dram_vref_reg_value 0x 0000005e
2D training succeed
auto size-- 65535DDR cs0 size: 2048MB
DDR cs1 size: 2048MB
DMC_DDR_CTRL: 00e00024DDR size: 3928MB
cs0 DataBus test pass
cs1 DataBus test pass
cs0 AddrBus test pass
cs1 AddrBus test pass
100bdlr_step_size ps== 478
result report
00000000
emmc switch 3 ok
Authentication key not yet programmed
get rpmb counter error 0x00000007
00000000
emmc switch 0 ok
Load FIP HDR from eMMC, src: 0x00010200, des: 0x01700000, size: 0x00004000, part: 0
Load BL3X from eMMC, src: 0x0006c200, des: 0x0175c000, size: 0x000ec000, part: 0
0.0;M3 CHK:0;cm4_sp_mode 0
MVN_1=0x00000000
MVN_2=0x00000000
OPS=0x30
ring efuse init
28 0c 30 00 01 1d 29 00 00 01 35 38 37 43 46 50
[0.017150 Inits done]
secure task start!
high task start!
low task start!
run into bl31
NOTICE: BL31: v1.3(release):4fc40b1
NOTICE: BL31: Built : 15:57:33, May 22 2019
NOTICE: BL31: G12A normal boot!
U-Boot 2021.07-24136-g50c984a15b (Jun 28 2022 - 21:00:58 +0800) radxa-zero
Model: Radxa Zero
SoC: Amlogic Meson G12A (S905Y2) Revision 28:c (30:2)
DRAM: 3.8 GiB
MMC: sd@ffe03000: 0, sd@ffe05000: 1, mmc@ffe07000: 2
In: serial
Out: serial
Err: serial
Net: Net Initialization Skipped
No ethernet found.
starting USB...
Starting the controller
USB XHCI 1.10
scanning bus usb@ff500000 for devices... 1 USB Device(s) found
unable to select a mode : -5
Device 0: unknown device
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-meson-u200
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
No ethernet found.
No ethernet found.
G12A:BL:0253b8:61aa2d;FEAT:E0F83180:2000;POC:D;RCY:0;USB:0;0.0
bl2_stage_init 0x01
bl2_stage_init 0x81
bl2_stage_init 0xc0
bl2_stage_init 0x02
L0:00000000
L1:00000703
L2:00008067
L3:04000000
S1:00000000
B2:00002000
B1:e0f83180
TE: 15785205
Board ID = 2
Set cpu clk to 24M
Set clk81 to 24M
CPU clk: 1200 MHz
Set clk81 to 166.6M
board id: 2
DATA transfer complete...
fw parse done
AML DDR FW load done
PIEI prepare done
LPDDR4 probe
ddr clk to 792MHz
dmc_version 0000
Check phy result
Check phy result
Check phy result
1D init succeed
Check phy result
channel==0
RxClkDly_Margin_A1==216 ps 11
VrefDac_Margin_A1==23
channel==1
VrefDac_Margin_A1==25
soc_vref_reg_value 0x 00000016 00000015 00000014 00000015 00000014 00000013 00000016 00000016 00000014 00000016 00000015 00000013 00000014 00000015 00000014 00000016 00000016 00000016 00000015 00000017 00000017 00000015 00000018 00000016 00000018 00000015 00000016 00000017 00000015 00000013 00000013 00000016 dram_vref_reg_value 0x 00000061
2D init succeed
ddr init done, boot next stage
result report
Data req end
RUN bl2 usb boot
MVN_1=0x00000000
MVN_2=0x00000000
OPS=0x30
ring efuse init
[0.017149 Inits done]
secure task start!
high task start!
low task start!
run into bl31
<debug_uart>
U-Boot 2022.07-00006-g9cfab85fe (Sep 05 2022 - 19:01:11 +0800) radxa-zero
Model: Radxa Zero
DRAM: 3.8 GiB
Core: 383 devices, 23 uclasses, devicetree: separate
In: serial
Out: serial
Err: serial
Net: No ethernet found.
starting USB...
USB XHCI 1.10
Enter ums mode. Press Ctrl+C to stop...
** Invalid partition 1 **
Couldn't find partition mmc 2
Something went wrong. Printing debugging info...
=> mmc list
sd@ffe03000: 0
sd@ffe05000: 1
mmc@ffe07000: 2 (eMMC)
=> ls mmc 0
** Bad device specification mmc 0 **
Couldn't find partition mmc 0
=> ls mmc 1
** Bad device specification mmc 1 **
Couldn't find partition mmc 1
=> ls mmc 2
You are now at U-Boot shell.
You can use either u-boot.bin or rz-fastboot-loader.bin or any other loader that gives you access to Zero’s eMMC. However, if you loading with rz-fastboot-loader.bin and using fastboot on your PC/Mac you may find that
