- Avoid USB-PD chargers. Make a cable so you can feed it with a good fixed voltage PSU. The specified range is 9V to 20V. I have a 12V/72W PSU. I used a USB to screw terminal block that works great for this.
- It needs cooling for any serious use. I found an old 40mm cooler in my drawer that I used.
EDIT: If you are running from an SD Card. Make sure it is A1 rating.
This has given me a very stable system. It ran s-tui stress for several hours.
