Semaar
March 24, 2020, 6:30pm
1
I quote:
You can always flash the rock, it never bricks unless some hardware damage occurs.
My MXQ-4K was looks fine, until I was tried to upgrade. I have Fedora Linux, and I like Linux. With RkFlashKit I was recognize the rk-3228 chip on MXQ-4K board, and several times flashed firmware by partitions via RkFlashKit - unsuccessful. Then,
./upgrade_tool uf /opt/update_7.1.2_rk3328_public_8189etv_20170616.img
Loading firmware…
Support Type:RK322H FW Ver:7.1.00 FW Time:2017-06-16 19:13:43
Loader ver:2.39 Loader Time:2017-03-31 20:47:59
Hm-m? I tried
./upgrade_tool uf /opt/update-rk3229_5.1-mxq_4k-ota_v0-20160516.img
Loading firmware…
Support Type:RK322A FW Ver:5.0.00 FW Time:2016-05-16 20:00:58
Loader ver:2.31 Loader Time:2016-05-16 17:47:09
Wait For Loader Fail - and at this point I got the brick.
The board doesn’t recognized in lsusb list with factory reset pressed, the red led on board is lighted.
Lili
March 25, 2020, 1:26am
2
I think you need to go into maskrom mode
Semaar
March 25, 2020, 11:20am
3
Right said! Got it, connected 7-8 pins and voi la -
lsusb
Bus 001 Device 064: ID 2207:320b - live!
However - stopped on
tool said -
Download Boot Start
and waiting…
I think I need run:
upgrade_tool db out/u-boot/rk3328_loader_ddr786_v1.06.243.bin
upgrade_tool wl 0x0 out/system.img
upgrade_tool rd # reset device to boot
When I try
./upgrade_tool db rk3328_loader_ddr786_v1.06.243.bin
got
Open loader failed,exit download boot!
Semaar
March 25, 2020, 12:06pm
4
Semaar:
./upgrade_tool
Rockusb>UL rk3328_loader_ddr786_v1.06.243.bin
Loading loader…
Loading loader failed!
Rockusb>UL rk3328_miniloader_v2.43.bin
Loading loader…
Rockusb>UL /opt/img_MXQ-4K_ota/loader.img
Loading loader…
Rockusb>UL /opt/rk3228/img/loader.img
Loading loader…
Semaar
March 25, 2020, 1:46pm
5
Linux_Upgrade_Tool_v1.21]# ./upgrade_tool
List of rockusb connected
DevNo=1 Vid=0x2207,Pid=0x320b,LocationID=141 Maskrom
Found 1 rockusb,Select input DevNo,Rescan press ,Quit press :1
Rockusb>RS 0x00002000 0x00004000
Error:Read sector failed!
Rockusb>TD
Test Device Fail!
Rockusb>
Semaar
March 25, 2020, 7:16pm
6
Rockusb>UL /opt/img_rk3229/update/RK322XMiniLoaderAll_V2.31.bin
Loading loader…
Support Type:RK322A Loader ver:2.32 Loader Time:2017-05-18 16:12:59
Upgrade loader ok.
Rockusb>TD
Test Device OK.
Rockusb>RID
Flash ID:AD DE 14 AB 42
Rockusb>RFI
Flash Info:
Manufacturer: HYNIX,value=02
Flash Size: 8448MB
Block Size: 4096KB
Page Size: 16KB
ECC Bits: 40
Access Time: 32
Flash CS: Flash<0>
Rockusb>RCI
Chip Info: 41 32 32 33 0 0 0 0 0 0 0 0 0 0 0 0
mo123
March 25, 2020, 7:21pm
7
You have a rk322x device probably still with nand storage, so don’t flash rk3328 firmwares or bootloaders since that will brick your device.
Semaar
March 25, 2020, 7:38pm
8
mo123 , already bricked once!
Now try to load firmware,
Rockusb>UF /opt/MXQ_4k_1GB_8GB_Andr_5.1_Superceleron_v1.0.img
Loading firmware…
Support Type:RK322A FW Ver:5.0.00 FW Time:2016-07-30 03:12:54
Loader ver:2.31 Loader Time:2016-06-22 21:15:53
Wait For Loader Start… and -
Semaar
March 26, 2020, 10:11am
9
I have restored with command
./upgrade_tool uf /opt/mxq-4k_1G8G_rtl8189_20171113_r1.img
However, the screen is showing only MXQ-4K logo
RkFlashkit show more - looks like itsa rk3228 nor rk322x device!
Reading flash information
Loading partition information
MACHINE_MODEL:rk3228
MACHINE_ID:007
MANUFACTURER:RK30SDK
MAGIC: 0x5041524B
ATAG: 0x60000800
MACHINE: 3228
CHECK_MASK: 0x80
KERNEL_IMG: 0x60408000
#RECOVER_KEY: 1,1,0,20,0
#CMDLINE:console=ttyFIQ0 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00004000@0x00004000(trust),0x00002000@0x00008000(misc),0x00000800@0x0000A000(baseparamer),0x00007800@0x0000A800(resource),0x00006000@0x00012000(kernel),0x00006000@0x00018000(boot),0x00010000@0x0001E000(recovery),0x00020000@0x0002E000(backup),0x00040000@0x0004E000(cache),0x00008000@0x0008E000(metadata),0x00002000@0x00096000(kpanic),0x00400000@0x00098000(system),-@0x00498000(userdata)
CMDLINE:console=ttyFIQ0 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00004000@0x00004000(trust),0x00002000@0x00008000(misc),0x00000800@0x0000A000(baseparamer),0x00007800@0x0000A800(resource),0x00008000@0x00012000(kernel),0x00010000@0x0001A000(boot),0x00010000@0x0002A000(recovery),0x00020000@0x0003A000(backup),0x00040000@0x0005A000(cache),0x00008000@0x0009A000(metadata),0x00002000@0x000A2000(kpanic),0x00400000@0x000A4000(system),-@0x004A4000(userdata)
Partitions:
uboot (0x00002000 @ 0x00002000) 4 MiB
trust (0x00004000 @ 0x00004000) 8 MiB
misc (0x00002000 @ 0x00008000) 4 MiB
baseparamer (0x00000800 @ 0x0000A000) 1 MiB
resource (0x00007800 @ 0x0000A800) 15 MiB
kernel (0x00008000 @ 0x00012000) 16 MiB
boot (0x00010000 @ 0x0001A000) 32 MiB
recovery (0x00010000 @ 0x0002A000) 32 MiB
backup (0x00020000 @ 0x0003A000) 64 MiB
cache (0x00040000 @ 0x0005A000) 128 MiB
metadata (0x00008000 @ 0x0009A000) 16 MiB
kpanic (0x00002000 @ 0x000A2000) 4 MiB
system (0x00400000 @ 0x000A4000) 2048 MiB
userdata (0x00BDC000 @ 0x004A4000) 6072 MiB
Done!
Lili
April 7, 2020, 10:27am
10
Is the firmware you are using officially released?
Also have a same problem
My box was stuck at android logo downloaded firmware for rk322x and installed firmware but now its not powering on ,light is red now
Can Any one share original firmware of mxq pro 4k With R322x chip
Thanks
mo123
July 14, 2021, 3:07am
12
@yasir_siddique
Please stop spamming the thread.
