I’ve installed and using libmraa on a RockPI S v1.3.
Generic Input and Output is working.
But:
Input_PullUp and Input_PullDown is not really, or anyone has a working example?
Pwm.write() works as reversed
I’ve tested Pwm functions with a simple LED. When i am using led.write(0) the LED is the brightest, with led.write(0.5) are half-bright, and with led.write(1) the LED is not lighting.
- Pwm.enable(False) is not working at all
After testing Pwm and setting enable(False) at the end, the LED still lighting, which means that Pwm is still working? How can i switch it off really?
