MQTT mosquitto server
Has anyone managed to get mosquitto server running on Armbian focal 5.10. I update and upgrade and then try use
sudo apt-get install mosquitto
At this step it errors:
Setting up mosquitto (1.6.9-1) …
Failed to reload daemon: Connection timed out
I then try and repair using:
sudo dpkg --configure -a
and it seems to progress but the board runs very unstably - sometimes hanging.
When trying to stop / start using sudo systemctl restart mosquitto get more errors - which I have not copied down unfortunately as am now rebuilding the OS yet again - but looks as if it has not started.
Which board are you using and what kernel version?
I think mosquitto is just software libraries and stack, right?
Rock Pi S.
I have no idea why it fixes it - but if you run
sudo apt-get purge mosquitto
it then loads and behaves.
