I have purchased ROCK PI4 B for the installation of Moode Audio Play, but the current firmware is PINE ROCK64. The current firmware works well and the CPU is RK3328. However, the resources of this chip are not enough. Thank you very much!
An ISO image for another hardware will not work, so it does not help that the hardware is similar. If I read that the source code for the Raspberry Pi only works on a specific Raspbian version, then success on the target hardware is questionable despite compiling it yourself.
Thank you very much! It seems that the currently available RK3328 firmware does not work on ROCK PI4B! It seems that the compiler can not ~~~IO, BOOT a lot of different ~~~
So… will MoOde work with the Rock Pi products?
