I’m following the instructions for building the kernel here:
https://wiki.radxa.com/Rock5/guide/build-debian-from-debos-radxa
However, ko modules built here can not be loaded through insmod. I am receiving the error:
insmod: ERROR: could not insert module /tmp/squashfs.ko: Invalid module format
I’ve confirmed that the same module from the distro does load. Are there extra steps or missing flags? The “file” output on both modules is the same (different hash)
ELF 64-bit LSB relocatable, ARM aarch64, version 1 (SYSV), BuildID[sha1]=XXXX, not stripped
Thanks
